motor mount
many have had them go bad at less mileage.i had my first one replaced with my first tranny at around 75k. last time i was in around 159 k they said the fron one is bad. appearently they dont last long??
Boomer SOONER
Easy way to check is pop the hood. Have someone watch the motor, and rev it a little in park. If it jumps a lot, its a bad mount, if it just moves slightly, thats normal. Also you can shift it into drive and if it hops a lot thats another sign.
From what your describing, it sounds like its a motor mount.
also look at the front one for cracking on top, or like the rubber id tearing or pulling apart where the bolts go in
the motor hops around when letting off the gas...and torques up when stepping on the gas.
we had it on the lift in gear.
the mechanic said it would be even worse when the car was under it's weight.
i told them to fix it.
xsilverhawkx
09-28-2015 06:51 PM
