motion sensor
Old Feb 12, 2001 | 08:44 PM
truplaya68's Avatar
Question motion sensor
Does anybody know how or where i can find a motion sensor that would work with the factory alarm system or could be added to the factory alarms system?
ankit
Old Feb 12, 2001 | 10:29 PM
NighthawkBlack's Avatar
Post
I'm hooking up a glass sensor from DEI this weekend. I was told that I could piggyback a dual shock sensor from DEI. I think it is a 504M or 504 T something like that. The important thing is that it has a negative trigger lead like all the sensors door lock etc on our TL's have. Hope this helped.
Old Feb 12, 2001 | 10:36 PM
Nate's Avatar
Post
Don't think you can add a motion sensor to the stock alarm... mr. tl played with this I think?
Why would you need a shock AND a glass sensor?
Old Feb 13, 2001 | 01:52 AM
Post
almost any shock sensor (or glass sensor and motion/proximeter sensor for that matter) has a power lead, and ground lead, and a ground trigger wire. All these sensors should be compatible to hooking up to the grnd trigger wire on the stock alarm. A diode may be needed though to prevent a feedback signal from going from one sensor to the one you've piggy backed. Otherwise, everytime a sensor triggered, you may activate your dome light if you piggybacked it to that sensor wire. DEI, Clifford (same co, diff productlines), and several others have really good sensors out.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by yu888 on February 13, 2001 @ ]</font>
Old Feb 13, 2001 | 01:26 PM
sutlTL's Avatar
Post
I spliced a shock sensor, not sure what brand, into the door light wire. I'm not sure if the interior light goes on when the alarm is triggered but it doesn't matter as long as the siren (I changed that too) is wailing!
RobbDizzle
Oct 15, 2015 11:16 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
