More problems
Old Apr 3, 2003 | 10:19 AM
kkambbak9399's Avatar
More problems
when my car is at idle, the car shakes. like the car isn't getting enough gas or something. anyone else with this problem?
Old Apr 3, 2003 | 10:31 AM
BK99TL's Avatar
i have the same problem
Old Apr 3, 2003 | 11:16 AM
SilverUA5's Avatar
dirty injectors? bad gas? dirty throttle body? could be a number of things.
Old Apr 3, 2003 | 12:05 PM
BK99TL's Avatar
can the injectors be cleaned without going to the dealer?
Old Apr 3, 2003 | 12:27 PM
yes they can be cleaned...i have 56k, and i had mine cleaned about 2 weeks ago...........just look for a shop that does injector cleaning in yur area!
Old Apr 3, 2003 | 02:05 PM
i put in the best gas. injectors? can this be covered under warranty?
Old Apr 3, 2003 | 03:19 PM
Strannik's Avatar
First, look at your tach, how many RPMs have you got? And does the needle shake? You may have a bad spark plug, or ignition mogule, or something else causing 1 cylinder not to work.... Most likely covered under warranty
Old Apr 3, 2003 | 04:34 PM
can you drive without 1 cylinder working? :wow:
Old Apr 3, 2003 | 07:21 PM
Darkshear's Avatar
l33t
Im getting the BG treatment at the dealer later this week... it cleans out the exaust, intake manafold, injectors, and fuel system.... $100 at the dealer... but you cant do it yourself...
Old Apr 3, 2003 | 08:10 PM
2001TL4KCdude's Avatar
Oracle Apps/Database Dude
are puting in 91 octane gas? 87 octane give me the 'shivers' when idling
Old Apr 4, 2003 | 10:33 AM
well, brought my car to the dealer. the service manager took it for a drive. only when the car is in PARK, it starts to shake. i'll let you know what happens. he says its most likely dirty injectors cos when a cyliner misfires, a check engine light will usually come on. you know i checked my past service records and ive been the dealer every single month for the past 8 months to have something fixed.
Old Apr 4, 2003 | 10:34 AM
yes 91.
Old Apr 4, 2003 | 10:41 AM
AndySara's Avatar
You could also have him check:
1) Idle boost controller
2) Engine mount. One of them could be damaged
Old Apr 4, 2003 | 10:52 AM
thanks. i had the front engine mount replaced last month.
Old Apr 4, 2003 | 02:08 PM
ok they said i need to flush out the fuel injection($100) and tighten the valves($345)!! i was like heck no! so they are checking to see if these things can be covered under warranty. i swear i had a 1998 honda accord(100K miles) before this and never did i have any problems of these kind.
i have 59K on my car. is this normal?
:flamer: acura
Old Apr 4, 2003 | 06:26 PM
ok its certain now. theres a valve misfire. they said its gonna cost $345. is this just a wear and tear problem? or is it an engine defect?
thanks
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
