misaligned doors
Not sure how easy it is to fix
My friend had the problem on his Silver 99TL. But, his car was totaled on the highway. I remember him telling me that he believed he was getting more Wind noise in his car than mine, probably because of the misalignment.
If 3/4 doors are misalignment, and dealer can't fix the problem properly, does that count as a "Lemon"?? Or does Lemon has to be defects that impairs/endangers the passengers??
Andy Kuo
'92 Mercedes-Benz 400SE
Pearl Grey/Black
'02 Acura TL-S
Satin Silver/Ebony
Mercedes-Benz S-Class
Andy Kuo
Pearl Grey/Black
'02 Acura TL-S
Satin Silver/Ebony
Visibly noticeable. The side belt line is lower for the front door, and the chrome line of the rear right door doesn't line up with the chrom line on C-Pillar. Driver side door panel is not flush when looking from the side....
Though, all doors close properly..
Andy Kuo
Pearl Grey/Black
'02 Acura TL-S
Satin Silver/Ebony
Andy Kuo
Pearl Grey/Black
'02 Acura TL-S
Satin Silver/Ebony
Ugh -- that doesn't sound good.
Although, the night i drove the TL-S home from the dealership, I immediately began to notice quailty and craftsmanship differences (for the worse) comparing our '99 Benz and our old '94 ES300 (which was flawlessly crafted, believe it or not). The Lexus' and MB's are just built better in terms of fit and finish. I'm sure they're no more reliable than an Acura, but it'd be nice to include that *feature* in a $30K sedan! I was watching t.v. today and saw a commercial for the Toyota Avalon -- the car in the commercial was $33,600 (fully loaded) and had the wood dash and .. man.. the quality was impeccable! The interior looked better than an ES300's!
Originally posted by 1000bpm:
Dammitt .... first it was the uneven tailp ipes then the creaks now this.
One more thing to check before I get into my TLS tomorrow morning.
Guest
Posts: n/a
Andy Kuo
Andy Kuo
I checked my doors earlier today and the silver trim just above the handle on the drivers side front door is lower than the silver trim on the rear door. From a distance you can't really tell, but upon closer inspection it is apparent.
The door opens & shuts OK, and is flush w/ the other body panels. No problem there.
I know there was at least another owner in this thread who had the same problem. What happened, was you dealer able to realign the panels?
If its a relatively minor adjustment, I will have my dealer take a look at it. If its a major operation, I probably won't. Wouldn't want them to screw things up further .....
All doors work fine, maybe I am being picky, but I DO expect Acura to have quality fit/finish as Toyotas.
Also, I am afraid that, after dealer send it to body-shop and re-aligned the doors, will it make the door rattles in the long run?? What steps are involved when doing door re-alignments??
1000bpm,
I have the same problem as you, but mine is on the passenger side, and it's not obvious from a distance, but upon close up, you definitely will see the uneven trims
1000bpm,
My WDP TL-S finally showed up, "gift wrapped", straight off the truck.
I am supposed to pick it up Monday/Tuesday but upon initial inspection this evening, I also noticed it's doors are not aligned horizontally. Vertically they look fine. The trunk lid is also misaligned on the right rear corner.
It's VIN is in the 10K range, so Acura hasn't fixed anything yet. It also has the usual issues of the RH tailpipe not centered.
What really irritates me is that most of the others on the lot (VIN 2000-3000) are perfectly aligned. The one I rejected earlier for mileage is also OK.
By the way, the build completion date is on a tuesday/wednesday.
Akry: I don't think you're being too picky here. For $32k I think its reasonable to expect the doors to be perfectly aligned
Lonny: please let us know what happens after your trip to the dealer.
I wonder if this has anything to do with early production runs. A buddy of mine who's had his TLS for a little over a month now has the same misalignment of the silver trim, but on the passenger side (mine's on the driver side). He also has larger-than-usual gaps (between the chrome strips) in the triangular shaped windows in the front & the back on the drivers side. His SN, like mine, is in the 1000's.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by rockinTLS on April 23, 2001 @ ]</font>
But Peter, I have never seen anyone under the age of 60 in a Toyota Babylon, other than those at least a foot under nromal height and 60 pounds overweight.
It is coma city - I would beg for a defect just to have some excitement in my life if I owned a Abaloney.
Rage On!
2002 TL-S w. Comptech header/exhaust
SSR Integral A2's
17x7 45mm offset
Pirelli P7000 (Summer) 215-50/17
Rage On!
SSR Integral A2's
17x7 45mm offset
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
