MikeB at Comptech
Old Nov 17, 2000 | 06:17 AM
MikeS's Avatar
Question MikeB at Comptech
I saw a thread earlier about the need to replace the factory shocks when we put the springs on the car. Can you shed any light on the subject?
Old Nov 17, 2000 | 08:42 AM
snook789's Avatar
Post
Mike, you don't "have" to change the stock shocks when you install lowering springs. Its just that your stock springs will not last as long due to the extra stress the lowering springs will put on them.
A few members on this board have the stock shocks and Comptech springs installed on their TL's for over a year and are still ok. But I would say in a couple years you will want to change out the shocks with some KONI's or Tokico's
Old Nov 17, 2000 | 10:46 AM
Guest
Guest
Posts: n/a
Post
It definitely is not required to change the shocks since the springs are only 10-15% stiffer than stock. But you will save on labor charges to have them done at the same time.
Old Nov 17, 2000 | 02:44 PM
Road Rage's Avatar
Not a Blowhole
Post
Have never given it a thought, but it would make sense that a more highly compressed shock has higher internal pressures, generates more heat as a result, and won't last as long.
Rage On!
2000 TL w. Comptech header/exhaust
SSR Integral A2's
17x7 45mm offset
Pirelli P7000 (Summer) 215-50/17
Fender lips rolled
Old Nov 17, 2000 | 05:19 PM
MikeS's Avatar
Thumbs up
Thanks for the info Guys....
2000 TL - Laguna Green, Navi, Rear Spoiler. Soon to have 17" wheels. Lowered 1.5" & Comptech Axle back Exhaust.
Old Nov 17, 2000 | 11:40 PM
Guest
Guest
Posts: n/a
Post
I don't see how the stock shocks will have more stress if the springs are stiffer. If the springs are stiffer doesn't that mean that the shock will work less? Well, I guess you can look at it both ways. But I think the biggest concern is the stock shock bottoming out, since the springs are shorter. But apparently, the shorter Comptech springs are compatible with the length of the stock shock.
Jul 16, 2017 07:33 AM
BoricuaTL
Apr 8, 2016 01:08 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
k6biv
Sep 22, 2015 02:06 PM
