Maintenance Required Light
Old Mar 30, 2004 | 05:42 PM
garticus's Avatar
7th Gear
Question Maintenance Required Light
How do you turn off the maintenance required light?? I know it's mileage dependant but what button(s) do you push to turn it off???
Old Mar 30, 2004 | 05:46 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
Garticus, hold down the "reset" and "trip" buttons, then turn the key to the "on" position. i think it will blink or something then reset. at least that is how you do it on an '02, i cant tell what year you have. it may also be in your owners manual how to do it (its in mine towards the back somewhere). hope this helps.
SSTS
**EDIT**
ah the "SELECT" not "TRIP" button, my bad. thanks hzm82.
Old Mar 30, 2004 | 05:47 PM
hzm82's Avatar
Information like this can be found in the manual, if you do not have one please purchase a replacement because it is very useful to have. With that said, to reset the maint light.
I.) Press & hold RESET & SELECT buttons together,
II.) While you holding those 2 buttons, put the key in igition to II position(Don't start the car)
III.) Maintenance light will start blinking. Wait until the Maintenance light turns off and let go those buttons
IV.) Start the car and make sure it's off.
Old Mar 30, 2004 | 06:04 PM
fsttyms1's Avatar
just to add to the above, it takes about 10 seconds
Old Apr 4, 2004 | 02:39 PM
tekman's Avatar
what do you so if the light isn't blinking but stays ON? i tried to take it off with the buttons mentioned above, but it won't come off...?
Old Apr 4, 2004 | 02:58 PM
NSX4dr's Avatar
Original Member #81
Search is your friend......
Old Apr 4, 2004 | 03:51 PM
fsttyms1's Avatar
its the same procedure. look in the manual. push and hold the reset and trip buttons then turn the car to the run position and hold the buttons for 10 sec (untill the light goes off)
Old Nov 14, 2006 | 02:10 PM
sporty_20001us's Avatar
reset maintance light acura TL 03
Hi here is how to reset maintance light
1. engine off
2. press and hold "reset" and "seclect" button at the same time
3. turn the key to " II " position ( II position mean u can see all the light airbag light , brake light ... are on but the engine still off)
4. when u hold reset and slect button and the key at II postion for 10 second u will see the mantance light flashing now u turn on the engine remmember when u turn on the engine u still hold down the reset and select button
5. when the engine on few second the maintance light will off and u are reseted , make sure it off u can do the same procedure if it not off.
remember u keep hold down the reset ans select button the whole time until the light is off
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
PortlandRL
Sep 14, 2015 12:01 PM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
