Maintenance Required Light
7th Gear
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
How do you turn off the maintenance required light?? I know it's mileage dependant but what button(s) do you push to turn it off???
ChairmanMaoSaysRTFM
SSTS
**EDIT**
ah the "SELECT" not "TRIP" button, my bad. thanks hzm82.
Information like this can be found in the manual, if you do not have one please purchase a replacement because it is very useful to have. With that said, to reset the maint light.
I.) Press & hold RESET & SELECT buttons together,
II.) While you holding those 2 buttons, put the key in igition to II position(Don't start the car)
III.) Maintenance light will start blinking. Wait until the Maintenance light turns off and let go those buttons
IV.) Start the car and make sure it's off.
just to add to the above, it takes about 10 seconds
Originally Posted by tekman
what do you so if the light isn't blinking but stays ON? i tried to take it off with the buttons mentioned above, but it won't come off...?
reset maintance light acura TL 03
Hi here is how to reset maintance light
1. engine off
2. press and hold "reset" and "seclect" button at the same time
3. turn the key to " II " position ( II position mean u can see all the light airbag light , brake light ... are on but the engine still off)
4. when u hold reset and slect button and the key at II postion for 10 second u will see the mantance light flashing now u turn on the engine remmember when u turn on the engine u still hold down the reset and select button
5. when the engine on few second the maintance light will off and u are reseted , make sure it off u can do the same procedure if it not off.
remember u keep hold down the reset ans select button the whole time until the light is off
1. engine off
BlkTxAcuraTypeS
10-18-2015 08:05 PM
ahsm
09-09-2015 08:35 AM
