lug nuts...
Old Apr 17, 2006 | 09:39 PM
wmah523's Avatar
TL Q(
lug nuts...
i just got my 18s installed today at the tire shop...the guy ask me if they came with the lug nuts (which i didn't have), and he said it'll be ugly and all stick out with the OEMs. then i went to AutoZone to look for some lug nuts that might be better fitment or style, which i found two kinds:
1. Exact OEM shape and style
2. Tuners, tube shape w/ clear center
so what do you guys use on your aftermarket wheels, one of those two?
and since my rims were 10 holes, there was still 5 (5x100) holes exposed, are there anything out there to have them cover up...cuz when i look thru them, i can see the rusted rotor...which is ugly!
any recommendation on which brand or type to get?
Old Apr 18, 2006 | 02:03 AM
wmah523's Avatar
TL Q(
....anyone....!?
Old Apr 18, 2006 | 08:54 AM
fahoumh's Avatar
Shogun Assassin
Maybe this thread has some information useful to you...?
https://acurazine.com/forums/showthr...highlight=nuts
Old Apr 18, 2006 | 12:27 PM
TunedTL's Avatar
Initial D
You need Muteki or Volk Racing lug nuts, acorn style m12x1.5
Muteki is cold forged, 36g per open ended lug nut.
Volk Racing is very expensive, but they are forged aluminum. Closed ended and weight about the same as Muteki open ended.
Both made in Japan.
Pick your color and enjoy slight gain in torque at front wheels. typical OEM weights 60g per.
Old Apr 18, 2006 | 02:50 PM
NSXNEXT's Avatar
You don't need to spend a fortune on lugs and locks like TunedTL posted. Check out this thread and it'll give you some insight.
Bottom line, Gorilla and McGard are excellent brands. Make sure you get a set of locks too.
Old Apr 18, 2006 | 03:39 PM
vtlec01's Avatar
Both made in Japan.
Muteki open ended are dope. cant even see them
Old Apr 18, 2006 | 04:04 PM
TunedTL's Avatar
Initial D
Yes, but no one notice the OEM ones either because lug nuts are more functional than fashionable . Do a search on the photo section of this forum and tell me how many members take a picture of their lug nuts.
Old Apr 18, 2006 | 04:20 PM
vtlec01's Avatar
ok and theyre just as functional
Old Apr 18, 2006 | 05:07 PM
TunedTL's Avatar
Initial D
Not to debate this with anyone but just share some facts.
Lighter weight at the wheels also give you some performance gains.
Cold forged steel lug nuts such as Muteki or Gorilla gets you additional weight saving over OEM. More importantly, these weight are not static weight, they are rotational mass that affects every time you accelerates or brakes. Conversation of energy, the energy used to make wheels moving AND rotating can be saved or used to push the car forward.
24g per lug nuts saving translates into 1 lbs of weight saving for 4 wheels.
People can say it is not a big deal to save 1 pound, but $670 comptech mufflers will get you less than 1 ft-lb gain according to Comptech's dyno chart
http://www.comptechusa.com/store/med...1999TLplot.pdf
You can get that gain (probably more) with a $30 lug nuts, that is across entire RPM band.
Old Apr 19, 2006 | 02:20 PM
wmah523's Avatar
TL Q(
and wut size for our car? 12x1.25mm or 12x1.5mm ?
Edit: never mind...got it!
M12 x 1.5 application: Fits Hondas, Acuras, Toyotas, Lexus, Mazda, Mitsubishi etc.
just to make sure, 12x1.5mm is the one right ??
neuronbob
23
Jul 16, 2019 10:48 AM
lland
Oct 4, 2015 04:47 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
Miyagi__
Sep 22, 2015 12:47 AM
NetGnome
Sep 7, 2015 08:33 PM
