Lower Ball Joints
Lower Ball Joints
Need an opinion on getting lower ball joints replaced. Oem Factory Parts vs Aftermarket, does this really matter for this part? Also the dealer is only recommending the lower ball joints to be replaced should I replace the entire knuckle assembly. All feedback & recommendations are appreciated
02 Type S if that helps! Hey HandyCaptd should we get the win tonight for 102 or tank it so that the Braves get so we dont play the Cards?? & Btw do you have a good mechanic who works on your car in philly or do you just go to the dealer??
As far as i know they all can be pressed out. Early on there was no balljoint in the parts list and acura made you replace the whole knuckle to get it. Now there are ball joints available.
I just hope they don't have to face the Cards, still a few scenarios that can play out. I'd like to see #102, but if they lose and face the Braves, I won't be compaining!
2001–03 3.2 CL – ALL
Acura Service Bulletin 06-015 June 21, 2006
Replaceable Ball Joints
BACKGROUND
A replaceable ball joint is now available that allows you
to replace only the ball joint and not the entire knuckle
assembly. This part is for one-time replacements only.
CORRECTIVE ACTION
Inspect the base of the existing ball joint before
beginning repair work. If the ball joint is not stamped
with the letter “B”, then you can replace only the ball
joint. If the letter “B” is stamped on the base, disregard
this service bulletin and replace the entire knuckle
assembly.
PARTS INFORMATION
Ball Joint: P/N 06523-S84-405
Spindle Nut: P/N 90305-SD4-003
Cotter Pin: P/N 94201-30220
As of this day, no one I have talked to (Acura/Honda Techs) can explain why the knuckle with the factory installed 'B' balljoint cannot be reused.
Applies To: 1999–03 3.2 TL – ALL
BACKGROUND
CORRECTIVE ACTION
assembly.
PARTS INFORMATION
BACKGROUND
CORRECTIVE ACTION
assembly.
PARTS INFORMATION
maybe in a microscopic level, the diameter of the opening increases after the lbj's have been replaced and not as secure.. lmao, just feeding you a bunch of b/s.. to the op, i opted for moog lbj's as a lot have recommended on this site. got them for about the same price as oem.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
