Looking for TSB's for 03 TLS
At one point someone had a few TSB's listed and we could print them out as attachments. Where is that email?
Take a look at this site for TSBs...
http://www.alldata.com/
Specifically here: http://www.alldata.com/recalls/index.html
Blown is Best
Most TSB's have been posted here or at A c u r a - C L . C O M at some point in time. If you search, they should show up in some form. The one's that should apply to your '03 will probably be
1) moon roof noise
2) Timing Belt Tensioner
3) Rotors
1) moon roof noise
3) Rotors
Try this :
http://www.acura-tl.com/forum/showth...&highlight=TSB
http://w w w.a c u r a w o r l d.c o m/forums/forumdisplay.php?s=&forumid=85
Remember to remove the spaces. Also, you need an Acrobat reader to view/ print the TSBs.
Bulletins for 2003 Acura 3.2TL V6-3210cc 3.2L SOHC (VTEC) PGM-FI
General Recalls
TSB Number Issue Date TSB Title
03-017 MAY 03 Campaign - PCM/Fuel Pressure Regulator Replacement
02-027 OCT 02 Campaign - A/T Warranty Extension
Service Bulletins
97-040 MAY 03 Keyless Entry - Description/Identification/Programming
01-017 MAY 03 Brakes - Pedal/Steering Wheel Vibrate When Braking
00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
03-006 MAR 03 Engine Controls - Idle Speed Inspection
03-003 FEB 03 Interior - Power Seat Rail Synchronization Update
03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
03-002 JAN 03 A/T - MIL ON/No Upshifts/Downshifts/Slipping
General Recalls
Service Bulletins
What should I be doing with this info for TSB'
Should I treat them like they are recalls and go have all the TSBs verified on my TLs at the dealer?
I not too sure of the significance of TSB versus a recall.
Well, like the old saying goes, if it ain't broke don't fix it. But for me it just serves as a reminder to look out for those small things that could be bigger when your warranty is actually up. The TSB means they've had a number of complaints and when the complaints come in they have advisement from ACURA on how to go about fixing it. With recalls, or campaign recalls is what the actually call them, you normally get a letter advising you of the potential problem or danger and ask that you come in and have it repaired.
