Look what happened when resetting Maint light
I was resetting the maintenance required light and kept holding the buttons down, I heard a beeping sound and my outside temp gauge was counting.....1.....2.....3.....
Has this happened to anyone else?
yes, its a way to set the temp if it is off. when i first got my car it was always 6 degres or so high. so i used that to fix it. i found it by accident when i was trying to reset my service light. the ignition has to be on the first position to reset, second for the temp.
Originally posted by andrews32
So the counting is the number of degrees you want to adjust the thermometer by? How do you tell if you want to add or subtract X-degrees?
Originally posted by 2001TL4KCdude
How do you true up the outside temperature? Stop by a bank and look at their temperature? Listen to the weather? hold a meat thermometer beside your car (lol)?
Everything will work....(I think...)
NO?????????
mada51589
05-03-2022 09:54 PM
