locked up
Old Nov 2, 2016 | 11:01 PM
craigteresa's Avatar
locked up
I purchased a 2000 3.2 to a few days ago at auction. Pulled it home on a tow dolly. Tried to start and engine was seized up. This morning I removed all plugs and hand cranked one full reveloution. Large amounts of fuel came out of all cylinders. Removed fuel pump fuse and used ignition switch to turn engine over until no gas was coming from the cylinder plug holes. Replaced fuel pump fuse. Turned Ignition switch on. Waited 15 seconds and turned engine over again. Fuel blew everywhere. What should I try first?
Old Nov 2, 2016 | 11:09 PM
Originally Posted by craigteresa
I purchased a 2000 3.2 tl a few days ago at auction. Pulled it home on a tow dolly. Tried to start and engine was seized up. This morning I removed all plugs and hand cranked one full reveloution. Large amounts of fuel came out of all cylinders. Removed fuel pump fuse and used ignition switch to turn engine over until no gas was coming from the cylinder plug holes. Replaced fuel pump fuse. Turned Ignition switch on. Waited 15 seconds and turned engine over again. Fuel blew everywhere. What should I try first?
​​​​​​​Also, the wipers will not shut off. Had to remove fuse to stop them.
Old Nov 2, 2016 | 11:40 PM
Sounds like the MICU is bad
dubz ASPEC
Jun 3, 2025 08:48 PM
thx1138
Sep 3, 2023 08:58 AM
RjG2
Oct 11, 2016 12:32 PM
James Kang
1G RDX Problems & Fixes
Jul 9, 2016 05:34 PM
Ryley
Feb 27, 2016 03:47 PM
