location of oxegen sensor
Old Apr 4, 2007 | 04:03 PM
orgnlprankster7's Avatar
08 Civic SI
my o2 sensor went, i got a new bosch sensor but i need to know spesificly where it is located, the one before the cat. can someone show me a diagram or somthing before i go crawlin under the car thx
Old Apr 4, 2007 | 04:35 PM
fsttyms1's Avatar
Crawl under the car and look at teh exhaust pipe under the motor. Right after the 2 pipes merge into 1 there should be a sensor sticking out to the drivers side from the exhaust pipe.
See the opening just before the flex pipe right after the 2 merge, thats where it goes
Old Apr 4, 2007 | 04:36 PM
08 Civic SI
thx fsttyms1 u da man
Old Apr 4, 2007 | 04:59 PM
08 Civic SI
i crawled under and found the sensor but i cant locate where the plug is to unplug the wire. it leads up behind the trans and disapears! any help
Old Apr 4, 2007 | 05:00 PM
fsttyms1's Avatar
its located just above the axle. Get a flash light you will see it. It doesnt go up too far
Old Apr 4, 2007 | 06:08 PM
08 Civic SI
thx i found it. was a bitch to get out but finaly did. the car runns so much smoother. check engine light didnt go away but im still glad i did this.
Old Apr 4, 2007 | 06:09 PM
fsttyms1's Avatar
Pull the clock back up fuse on the passengers side dash fuse panel for 10 min or so.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
RobbDizzle
Oct 15, 2015 11:16 AM
hrothgar02
Sep 28, 2015 11:08 AM
