Lights went out, please help
Old Dec 3, 2004 | 06:34 PM
alpswd's Avatar
Two days ago, I noticed that my left head light was out, along with both my driving lights (the ones on the outside bottom corners behind the oragne reflector). Also, both my fogs were out. So I ordered an hid bulb, thinking that this was the most important thing, and after installing it, the light still didn't work, but both my fogs now work. I checked all the fuses, and they seem to be good, the only other thing that I could think of is the "lighing relay" module that is inside the fuse box. What exactly does this do, and how can i tell if thats the problem? does anyone have any other suggestions?
BTW... i recently cleared my headlights and had some moisture in the left one, which I am assuming probably might have something to do with all this. Also, don't know if it means anything, but also I did the "fogs lights only" mod (fogs can turn on w/o headlights) ....but that was a long time ago, at least a year, so i wouldnt think that has anything to do w the problem.
Old Dec 3, 2004 | 06:44 PM
songoku's Avatar
BlingBling INSPIRE 32V
Did you check the ballasts? I've seen some members with ballast problem after moisture got inside the headlights.
Old Dec 3, 2004 | 06:47 PM
alpswd's Avatar
Taking off the bumper right now to check.... what exactly should I be looking for?
Old Dec 3, 2004 | 09:24 PM
alpswd's Avatar
well i checked the ballast and there was about a gallon of water in it....
I posted in teh blackmarket to find a new one and found someone who has a ballast from a 2000 tl... is this the same ballast used for 02-03's ?
Old Dec 4, 2004 | 09:05 AM
alpswd's Avatar
someone please help me out....
If I use a non-oem ballast, will the the light emitted from the two headlights be different ?(I will still be using the same 4300K stock bulbs on both sides).
Also.. does anyone know our stock ballast specs? (volts, watts)
would this work?...http://cgi.ebay.com/ebaymotors/ws/eB...category=36476
Old Dec 4, 2004 | 09:12 AM
fsttyms1's Avatar
the light outputs should be the same if you are still using the standard 4300. as for the 00 being the same as a 03 the only thing i know is different is the bulb type (due to the different headlight style) the plug is a little different for the bulb, but you can get it to work
Old Dec 4, 2004 | 09:18 AM
alpswd's Avatar
another thing... if i was to use an aftermarket hid kit, what would i do about the hole in the bottom of our headlights that is made to work with the stock one?
also, what is specific to d2r/d2s? just the bulb, or also the ballast and ignitor?
Old Dec 4, 2004 | 09:42 AM
phins2rt's Avatar
alpswd,
Don't pay $160 for a ballast! You should be able to get one for around $100-125. Check out HidTech.com. Their prices are kind of high, but you will get good equipment. Going rate for a brand new pair of ballasts (Hella) is 180-250. Good luck.
I would stick with the Hella Generation 3 ballasts (ballast/ignitor integrated) or the Matsushita ballasts (oem I believe). I am not sure if the 4th Generation hella (separate ballast and ignitor) would fit on our cars.
Old Dec 4, 2004 | 05:33 PM
alpswd's Avatar
OK, well now it seems as if my whole fucking electrical system is messed up. None of the accessory lights -- guage lights, rear lights, and everything else that would normally come on when you turn on the headlights will light up. Additionally, the ONLY lights in the front that work are one of my low beams, and my brights, which are now dimly lit even when they are supposed to be off. Someone please help me...
Old Dec 4, 2004 | 05:41 PM
bkzjimmy's Avatar
NiGhT rIdEr
WOW!.....i really feel bad for you.....try to make ur car look good and screw everything up....good luck on fixing it
Old Dec 5, 2004 | 12:39 PM
alpswd's Avatar
anyone?!?
Old Dec 6, 2004 | 01:12 PM
songoku's Avatar
Did you check the fuse again?
Old Dec 6, 2004 | 01:19 PM
fsttyms1's Avatar
or a relay?
Old Dec 6, 2004 | 03:47 PM
alpswd's Avatar
I rechecked both the fuses and the relays, and there all working. any other ideas?
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
