Lighting Question
Old Feb 17, 2002 | 03:54 PM
mbeebe's Avatar
TL Type-S Owner
Lighting Question
Is it ok to have PolarG M6's for the map lights and door lights. They are 18w and I am afraid that they may be to much wattage for the wire. Could some one please reassure me that it is ok.
Old Feb 17, 2002 | 04:06 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
Probably ok if you don't have them on for too long..
I would be more concerned about the area around the bulb and it maybe melting.. but again, it depends on how long you have them on for..
Old Feb 17, 2002 | 04:41 PM
Nate's Avatar
I doubt it will be a problem. I've accidentally left mine on for a few hours with no problems.
Old Feb 17, 2002 | 04:49 PM
asiankidd's Avatar
their 19watts instead of the stock 5 watts...plus the bulb is a lil bigger your lense will be the first to show signs of melting
Old Feb 17, 2002 | 08:04 PM
TypeSDragon's Avatar
Loving my 08 TLS!
You probably won't need to worry. There were several instances that I left my door and dome light on overnight in my garage. No melting or overheating. I have used Polarg bulbs for a long time. And they always lasts!
Old Feb 17, 2002 | 08:11 PM
Edub-TL's Avatar
Yeah, but do you have the Polarg M-6 bulbs in there?? These are larger than the Polarg M-4 which is the normal 168 type.. the M-6 are the W2 type which is the kind used for the reverse bulbs and also the CL-S uses the M-6 in their wannabe fog lamps..
On the CL board, alot of members who have replaced thier stock fog lamps with M-6 bulbs have had problems with it melting the housing and the bulb expanding and breaking making it very hard to take out.. Of course the map and door lights won't be on nearly as long as the fogs, but at least people wanting to use the M-6 on their interior bulbs should know this..
Old Feb 17, 2002 | 08:37 PM
asif2002's Avatar
How blue and bright is it? How much dose it all come out to approx. to do the whole interior of the car?
Old Feb 17, 2002 | 10:20 PM
mbeebe's Avatar
TL Type-S Owner
They are bright as sh!t but I decided to take them out and use them for the reverse lights for safety reasons. I did the whole interior including dome, maps, 4 doors, glove box, trunk, reverse lights and trunk for a little under a hundred dollars. It took 5 sets of polarg M4's, a PolarG M28, and two PolarG M6's. It is worth the money the results are amazing.
mada51589
Jan 9, 2025 04:40 PM
eastcoastguy
Sep 24, 2015 02:07 PM
wusty23jd
Sep 24, 2015 11:41 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
