LED interior conversion... work in progress.
Old 03-21-2007, 10:56 PM
  #41
3.2TL
ThreePointTwoTeeEl's Avatar
Ohh yea, How difficult or easy was it do do all that stuff.
Old 03-22-2007, 12:16 AM
  #42
OntarioTL's Avatar
Originally Posted by ThreePointTwoTeeEl
Im going to do Red...The A8 I was in had red buttons and it looked amazing. So I will do that with White LED footwell lighting.
Unfortunately you can't do all red....some buttons have a blue filter installed, so red will be filtered out when lit. I tried to remove the blue filter but I ended up screwing up the label altogether.....but with that experience I had another thought........
There is sort of another way........but it might look ghetto. My dimmer switch label which I had to custom make as that was my guinea pig and it was screwed up....the replacement I made turned out nicely....and I now can have red installed.
Old 03-22-2007, 12:33 AM
  #43
AcuraBaby215's Avatar
Damn!!!! How do you do that????!!!!!!!!! I would pay someone to do that!!! I really want to change the colors of my lights especially the gauges. GrRrR!!!!!
Old 03-22-2007, 05:57 AM
  #44
speedbawlinTL's Avatar
Originally Posted by 02TLSfan
LEDautomotive uses hyper-white for the guage cluster, they appear blue-ish, plus the back of the dash cluster only has a few lights in it for the guages. 1 for the tach, 2 for the speedo, and 1 for gas/temp, plus the factory bulbs for those sections are bigger than all the others, closer to 10mm. The 3rd gen TLs use a string of lights, I believe, or so I've been told by Acura, but I've never had the pleasure of taking apart a 3rd gen(dealers tend to frown when you take apart a loaner).
those dealerships... so if the LEDs in those kits aren't bright enough, are there brighter bulbs that I could buy that would match the blue in 3Gs better? I just want to know if the colors are noticably different... If the blue isn't similar to that of 3Gs (the blue in the photos on LEDautomotive's website looks very dull), I'm not even going to risk wasting my time or parts by trying
If there are brighter bulbs that I can buy, will I run into trouble with fitting them like truexh did in the thread gaping46and2 linked to? this is an intriguing idea and I'd love to go through with it, but like I said, I don't want to screw up and fry something, especially if the color's not what I'm looking for
Old 03-22-2007, 11:54 AM
  #45
3.2TL
what do you mean I cant do all red.....I thought that blue filter could be taken out like in the DIY of the LEDautomitive website....I remember I think they take it out, and which ones cant I do red....I was gonna do the radio red and all the other button......And how did CaliChris do all of his buttons white? I think if he could do white, Red would be possible.
Old 03-22-2007, 12:35 PM
  #46
SOLD: 03 SSM CLS Auto
gaping46and2's Avatar
There are certain switches that the blue filter is not removeable, i.e: fogs, sunroof, vsa/cruise. The ring around the climate knobs are also not removable. Other than that, the radio, climate buttons and gauges are removeable.
Old 03-22-2007, 12:59 PM
  #47
OntarioTL's Avatar
Some filters are removable, but some are painted right on the label. The only buttons that have the blue filter that cannot be removed (yet) are dimmer, fog, sunroof, cruise, and for 99 model the power window main switch.
Old 03-22-2007, 05:17 PM
  #48
3.2TL
Hmmm......I actually used nail polish remover to remove that green and red filter on the shift gate thing...I bought SubtleDreamers thing but when I actually took out the stock shifter, I looked closely and I knew I could take it off with the remover...if you have your stock shifter and look on the underside youll see what Im talking about......Im thnking maybe I could do that. If anyone has there stock shift gate indicator, tell me if its the same type filter as those buttons if you would be so kind thanks.
Old 03-27-2007, 01:48 AM
  #49
Prick of the month
02TLSfan's Avatar
I posted some pics here...
https://acurazine.com/forums/showthread.php?t=155924
Old 04-03-2008, 03:00 AM
  #50
Your Garage
DC3328's Avatar
hey chris, is changing the climate control lights that much different than the non navi one? like subtledreamer showed, different bulbs or anything? thanks!
Old 04-03-2008, 03:05 AM
  #51
caligirl2k's Avatar
Great job..
Old 04-21-2008, 11:19 PM
  #52
jmunn's Avatar
where can you get l.e.d.s from
oo7spy
06-19-2023 12:48 AM
02-25-2020 09:57 AM
handsom-hustla
11-13-2015 05:04 PM
acurajj
09-19-2015 03:47 PM
Quick Reply: LED interior conversion... work in progress.
