leakage????
You can diagnose the leak by looking at the color of the fluid. Pink is transmission fluid, dark brown is oil.
In either case I'd take the car back to the dealer immediately.
2000 WDP 3.2TL non-NAV
AEM CAI en route...
AEM CAI en route...
Just because you live in Minnesota doesn't mean it's not the AC. If you are using the automatic climate control, it may be running the A/C compressor to remove moisture from the air, even if it's not cooling.
Even before I had the TL, I always ran my A/C in the winter and just turned up the temperature - keeps the windows from fogging up. The climate control system may be doing this for you, which would explain the condensation dripping from the car. Of course, check out the other possibilities but don't rule out completely that it could be the AC.
