L.E.D right blinker PROBLEM
Old Oct 3, 2007 | 07:47 PM
illjuan3's Avatar
I installed the LED cluster kit but my right blinker wont blink..the lights outside blink it even makes the ticking noise but no light...and the left side works perfect...Wat could be the problem???
Old Oct 3, 2007 | 08:14 PM
datzdaboi's Avatar
B A N N E D
Bad led ?
Old Oct 3, 2007 | 09:11 PM
illjuan3's Avatar
nope switched sides and the opposite led did the same I think its the cluster board or maybe be a fuse but one blinker blinks. Is there fuses for the left and right side or just one fuse for them both?
Old Oct 4, 2007 | 01:35 AM
illjuan3's Avatar
Bump
Old Oct 4, 2007 | 06:40 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
should be one fuse for all blinkers if i recall. should be in your owner's manual as well. probably a bad LED set. sorry dude.
Old Oct 4, 2007 | 07:28 AM
BIGTUFFGUY's Avatar
2003 TL-S A-SPEC
that or you installed them the wrong way. rotate it 180. LEDS have a + / - and it matters which way its installed. Hope it helps.
Old Oct 4, 2007 | 11:46 AM
illjuan3's Avatar
rotated it switched sides even installed original bulb still no luck?
Old Oct 4, 2007 | 05:09 PM
illjuan3's Avatar
so i decided to let acura find the problem, after i put back all the stock bulbs. During the installation of the stock bulbs half of them dont even work now????
Old Oct 4, 2007 | 07:31 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Sounds like you might've fried the board. Read this thread:
https://acurazine.com/forums/showthread.php?t=183510
Old Oct 5, 2007 | 12:33 AM
illjuan3's Avatar
THAt guy on that thread is fucked my cluster is fine besides the blinker.
I went to Acura Today and the guy told me I would be better off buying a new cluster and or multiplex instead of paying them to inspect and have a toss-up of actually even finding the real problem. My interior lights that are not wrkin are actually blown its like the LED bulbs are resisting power and threw it to other components and blew lights. At this time i have all the LEDs in and everything is ok except the blinker and bulbs that blew, I have a new cluster on order and multiplex on order so we will see once they come in i will post results after to help other fellow Ziners!!!
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
