l.e.d. cluster help. pics
Old Nov 21, 2004 | 05:14 PM
UglyPsycho's Avatar
S = Slow
I need help with the led cluster. I put in white leds but they seem to be a purplish-blue and the gauges are dim and the part where the mileage is are bright. Any input is appreciated.
Old Nov 21, 2004 | 06:03 PM
UglyPsycho's Avatar
S = Slow
is there a lens or anything i have to take out?
Old Nov 21, 2004 | 06:21 PM
fsttyms1's Avatar
did you put them in all the sockets? they may not be a wide enough angle led also.
Old Nov 21, 2004 | 06:38 PM
UglyPsycho's Avatar
S = Slow
yes i put them all in. is there anything i can do to make them beam wider? what about the color?
Old Nov 21, 2004 | 07:08 PM
slikz's Avatar
1999 Acura 3.2 TL
hm, what kind of LED did you use?
Old Nov 21, 2004 | 08:53 PM
Street Spirit's Avatar
As far as I know, there is actually a light blue lens over the gauges. When combined with the regular yellow light from a halogen bulb, it creates the light green that you see on all the lit gauges/instrument panel. If you swab the bulbs to pure white, you will end up with a light blue cluster/buttons since you'll have white light coming through the blue-tinted lenses.
In terms of having the light output appear over a wider area, I've heard of people shaving the LEDs a bit so the light spreads.
By the way, I actually quite like the colour of yours now...I wouldn't mind it at all. In order to get a deeper, pure blue, I think you have to use blue LEDs, like what Tatewaki did.
Old Nov 21, 2004 | 09:02 PM
UglyPsycho's Avatar
S = Slow
how should i shave the led bulbs? what do i have to do to take out the blue tint? thanks
Old Nov 21, 2004 | 09:23 PM
fsttyms1's Avatar
u cant shave it to make the beam wider, atleast not that i know of. as far as teh color are you sure that they are white led's? because they shouldnt be coming thru blue with out them being blue. the factory would be lit up bleu if there was.
Old Nov 21, 2004 | 09:47 PM
UglyPsycho's Avatar
S = Slow
I'm pretty sure that its a white led becasue the cover is white. if it was blue it would be a blue cover.
Old Nov 21, 2004 | 10:19 PM
car_lost's Avatar
all led bulbs are clear... regardless of what color they light up.
if you shave the head of the bulb, the light will spread out more. use a knife and chop it off or sand it down.
also, how much $$ will it take to get you to do this for me?!?! (seriously though)
Old Nov 21, 2004 | 10:45 PM
UglyPsycho's Avatar
S = Slow
Shave the led bulb flat? I cant really do it for you till I get it right first haha. but when i master it then ill do it for you.
Old Nov 21, 2004 | 10:56 PM
You might want to try contacting Tatewaki. He's done the LED conversion with blue LEDs. He's posted pics in another thread. I don't believe he altered any of the LEDs though, so I think he has a few hot spots.
https://acurazine.com/forums/showthread.php?t=94665
Old Nov 22, 2004 | 02:43 AM
thescoundrel's Avatar
If you try to diffuse the led for a wider angle, you also lose some of its brightness. I ended up using a blue mylar film with a bright white bulb replacement...the color is more even but is not as bright as I like.
Old Nov 22, 2004 | 02:53 AM
genghis82's Avatar
how many and what types of LEDs did you have to buy?
Old Nov 22, 2004 | 07:43 AM
car_lost's Avatar
seriously dude. i really want to have this done. as a matter of fact, if you can do it within the next month... i could probably buy the spoiler off you as well. i have a buddy that was looking for one. i'll PM you about this as soon as you get it done the way you like it. make sure you post some progress pics along the way.
Old Nov 22, 2004 | 11:00 AM
Jput's Avatar
Hmm i think i might also due the blue led conversion
Old Nov 22, 2004 | 08:09 PM
UglyPsycho's Avatar
S = Slow
I took them all out and put it back to stock. Can anyone tell me where I can buy bright white leds? I'm going to start over. In the mean time my dash is still torn apart. haha
Old Nov 23, 2004 | 08:48 AM
car_lost's Avatar
www.superbrightleds.com
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
