l.e.d. cluster help. pics
S = Slow
I need help with the led cluster. I put in white leds but they seem to be a purplish-blue and the gauges are dim and the part where the mileage is are bright. Any input is appreciated.
did you put them in all the sockets? they may not be a wide enough angle led also.
As far as I know, there is actually a light blue lens over the gauges. When combined with the regular yellow light from a halogen bulb, it creates the light green that you see on all the lit gauges/instrument panel. If you swab the bulbs to pure white, you will end up with a light blue cluster/buttons since you'll have white light coming through the blue-tinted lenses.
In terms of having the light output appear over a wider area, I've heard of people shaving the LEDs a bit so the light spreads.
By the way, I actually quite like the colour of yours now...I wouldn't mind it at all. In order to get a deeper, pure blue, I think you have to use blue LEDs, like what Tatewaki did.
Originally Posted by UglyPsycho
how should i shave the led bulbs? what do i have to do to take out the blue tint? thanks
all led bulbs are clear... regardless of what color they light up.
if you shave the head of the bulb, the light will spread out more. use a knife and chop it off or sand it down.
also, how much $$ will it take to get you to do this for me?!?! (seriously though)
S = Slow
You might want to try contacting Tatewaki. He's done the LED conversion with blue LEDs. He's posted pics in another thread. I don't believe he altered any of the LEDs though, so I think he has a few hot spots.
https://acurazine.com/forums/showthread.php?t=94665
If you try to diffuse the led for a wider angle, you also lose some of its brightness. I ended up using a blue mylar film with a bright white bulb replacement...the color is more even but is not as bright as I like.
seriously dude. i really want to have this done. as a matter of fact, if you can do it within the next month... i could probably buy the spoiler off you as well. i have a buddy that was looking for one. i'll PM you about this as soon as you get it done the way you like it. make sure you post some progress pics along the way.
S = Slow
I took them all out and put it back to stock. Can anyone tell me where I can buy bright white leds? I'm going to start over. In the mean time my dash is still torn apart. haha
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
