Koni shocks?
Old Apr 22, 2001 | 03:17 PM
-Rz-UA5's Avatar
Post Koni shocks?
My Koni shocks just arrived.. ....
Gotta get it install it next week...i cant wait. Just to wanna ask u guys, who got shocks installed??? will they lower your car?
if so..how many inch? thx guys....
-Rz-RacingZone
99 TL Silver
-AEM CAI
-N1 Exhaust
-Eibach Prokit
-Custom Front grill
-Custom badge
-Polarg M-12 corner
-Polarg M-6 reverse
-Eurolite Xenon Highbeam
-OEM Body kit
-OEM Rear wing
-Neuspeed towerbar
-17"x8 BBS RKII
- Bridgestone Potenza
S-02 225/45/R17
Old Apr 22, 2001 | 03:21 PM
Shoofin's Avatar
Post
they don't lower your car at all.
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Old Apr 22, 2001 | 04:49 PM
typeR's Avatar
Post
Ed
if you got the koni yellows they can lower your car 25mm front 20mm rear they also have an oem perch postion that maintains stock ride
Old Apr 22, 2001 | 05:04 PM
Brewboy's Avatar
Post
Actually the Koni's are designed to lower about 1" with the EOM springs using the lower perch setting. The upper perch setting (which is the stock height)is designed to be used with aftermarket springs so as to not add to the the lowering amount of the springs.
Old Apr 22, 2001 | 05:17 PM
Guest
Guest
Posts: n/a
Post
They lower less than an inch. The wheel well gap is actually evened out well, with just that little drop. Rides a little harsh on Medium setting with rims on.
Old Apr 22, 2001 | 05:47 PM
Brewboy's Avatar
Post
Due to the rear being lighter then the front of the car, I found if you turn the rears 1/2 turn softer then fronts it won't be as harsh.
For those who have them, what's your settings? I think I've set mine at 1-1/4 and 3/4 turns for f/r, respectively.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Brewboy on April 22, 2001 @ ]</font>
Old Apr 22, 2001 | 09:47 PM
Guest
Guest
Posts: n/a
Post
I have med all around.
For some reason, I can't seem to turn one of the front ones all the way to hard. I dunno, ever happen to anyone else?
Old Apr 23, 2001 | 10:17 AM
Post
How do you adjust the rear shocks? Do you have to go in from the back seat or is the adjustment on the bottom now?
Fins^
2002 TL-S w/Navi
Satin Silver
Jul 16, 2017 07:33 AM
IIDXholic
3G RLX (2013+)
23
Oct 19, 2015 09:40 PM
StevieB1503
ILX
Oct 8, 2015 04:52 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
