Key Question on Programming
Old Nov 4, 2005 | 10:19 AM
ddayton217's Avatar
Hollywood
I searched this site and found out that I need the dealer to program the key to the car is this correct? also if I were to buy a extra key, say of eBay or the dealer will any Acura key work with my 02 TL Type-S? Or is it like the remotes that have the FCC ID etc? Any help would be appreciated...
Old Nov 4, 2005 | 10:39 AM
disgookonfiya's Avatar
i believe the actual key has a ship in it that transmit's the code, so in order to get a new key, you would have to order it throuugh a dealer, where they can order/program a key just using your vin number
Old Nov 4, 2005 | 11:05 AM
Bareback's Avatar
TL = Tranny Lubrication
Did you see this?
Originally Posted by TL_Fo_Life
1...your new key
2...a MASTER KEY (one with the remote in it)already programmed to car.
to program the transponder- (thats the immobilizer part)
sitting in dr. seat, put the master key in ignition, and turn to on.engine OFF. press the gas pedal 5 times to floor and release. now press brake 6 times (press and release)
remove master key from ignition. install new key and turn to on...engine off. press gas to floor once. now wait. the security light will blink for about 45-60 seconds, then it will go off if you did it correctly. once the light is off, car should start.
For the remote part. in drivers seat WITH DOOR OPEN. start with door unlocked. first put master key in ignition, turn to on, then back off and remove. using the lock/unlock button on drivers door. press lock.. then unlock 5 times.(lock,unlock,lock,unlock,lock,unlock,lock,un lock,lock,unlock)
Close drivers door, open drivers door.
Performe lock/unlock procedure again.
insert key in to ignition and turn to on, then back off and remove.(at this point the doors should lock and unlock by themselves ONCE)
Now press both lock and unlock buttons on REMOTE. release after about 1.5seconds. now press just the lock button on remote.
now open and close the drivers door a couple times to close programming. if you did it right, remote will now work.
Bareback's Avatar
Did you see this?
1...your new key
Old Nov 4, 2005 | 11:22 AM
ddayton217's Avatar
Hollywood
Wow...that one is weird..the part about stepping on the gas pedal! I'll give it a shot!
thanks!
Old Nov 4, 2005 | 11:29 AM
Bareback's Avatar
Again I am not if this works this is what was previously posted - GL
In order to get a key programmed at the dealer it cost me $25...
Old Nov 4, 2005 | 01:22 PM
ddayton217's Avatar
Hollywood
I did see that one but it looked very weird..I guess if it works...
Old Nov 4, 2005 | 01:24 PM
ABP-TLS's Avatar
Wifes Car
I just bought one Monday cost me $32 out the door took the guy 2 min to program it
Old Nov 4, 2005 | 01:35 PM
ddayton217's Avatar
Hollywood
From a dealer or ebay?
Old Nov 4, 2005 | 02:18 PM
Bareback's Avatar
Dealer - programmed the key - key was given by the dealer for free.
Old Nov 4, 2005 | 06:42 PM
ABP-TLS's Avatar
Wifes Car
dealer
Old Nov 28, 2005 | 08:55 PM
Girvin13's Avatar
5th Gear
yea my dealer wants 39.99 for the key with free programming
i think its a total rip off
the dam key dont cost that much and like said earlier--took about 2 mins
thats the stealership for ya
Old Dec 15, 2005 | 02:14 PM
Syama's Avatar
Programming new key on 2000 TL
Hi guys
Just purchased 2000 Tl with one master (red acura simbol on it) without any buttons on it. Yesterday, I've got a new key cut by dealer (Toronto) for $45 Canadian without programming and 97+tax to program it. I'm wondering how can I program it. The description I found in this thread (5 times gas and 6 times brake) doesn't work for me. Any input is appretiated.
P.S. I successfully programmed new (which is used) remote but to program a key didn't work...the security light *the key sign on dashboard) kept blinking forever
Old Dec 15, 2005 | 03:14 PM
TunedTL's Avatar
Initial D
Originally Posted by Syama
Hi guys
Did you close the door when programming the key?
Old Dec 16, 2005 | 12:10 AM
Syama's Avatar
Yes, I did. Also, when I called today to Acura dealership they said that th eonly way to program new key is to bring them an old along with new one and they'll do it for me using a 'computer". don't know whetehr it's true or not
Aug 15, 2019 12:58 PM
tman570
Jun 11, 2019 07:56 AM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 13, 2015 01:59 PM
datadr
Sep 12, 2015 09:12 PM
