key placement for starter???
Old Jun 11, 2006 | 02:53 PM
sundeep's Avatar
I installed a viper791 alarm/starter today, everyting works fine, except i dont konw where to put the key. When i click the starter button, it cranks, but doens't start fully. pretty sure cause the key isnt there. I tried holding it aroudnt eh iginition, but same thing. Any ideas??
Old Jun 11, 2006 | 03:06 PM
sundeep's Avatar
do i need some sort of bypass with this system??
thanks
Old Jun 11, 2006 | 05:32 PM
greygabe's Avatar
I think you need a bypass
Old Jun 11, 2006 | 10:34 PM
uncald4's Avatar
Former Sponsor
You shouldn't be installing anything. You just told us that you don't know what you're doing.
Buy a DEI 556HW or 556UW. Follow the instructions. Most car audio shops will have this in stock. Good luck.
Old Jun 11, 2006 | 10:48 PM
sundeep's Avatar
lol thnx man, i just thought i could keep the key somewhere close and use a copy of it without the transponder, but guess not. gota learn sometime, thnx again
Old Jun 11, 2006 | 11:09 PM
uncald4's Avatar
Former Sponsor
If you use the 556HW it will not require that you use a key. It is an Acura/Honda transponder code learning module. It is a bit tricky to program but read through the instructions. This costs about $50 bones.
If you use a 556UW it will require that you lose a key to the module. But you can tuck that module up under the dash wherever you like. Easy. Also costs $50 bones.
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
agupta3224
Sep 22, 2015 08:08 PM
