Just Installed mah Tweets! (pics soon)
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
wow, those tweeters are so awesome! I got Diamond Audio tweeters and the Diamond Audio Motorsport crossover. mounted the crossover in the pocket of the door panel, and did the tweets just like Ron. Thanks to Ron and Ed for instructions. I will post pic as soon as I get mah camera.
2000 Red Hot TL w/o nav
Burlwood Trim and Shift Knob
Wood Trim Set
Gutter Guard Grill
Nebraska Legal Darkest Tint
Goodyear Eagle HP Ultra Plus 225/55/16
Photos Of My RED HOT TL
Wood Trim Set
Gutter Guard Grill
The crossovers are the ones in M5 series and the tweeters are in the Hex series.
Diamon Tweeters and Diamond Motorsport Crossovers
Wood Trim Set
Gutter Guard Grill
Shock Sensor
Wood Trim Set
Gutter Guard Grill
Shock Sensor
how much are they, also are you running stock speakers?? Oh OH also.. how hard is the install?? Im dying for tweeters right now. Tell me every detail about them if you can.
TL-S w/navi
Comptech springs
AEM Blue CAI
35% tint
![](http://www.acura-tl.com/ubb/wink.gif)
TL-S w/navi
Comptech springs
AEM Blue CAI
35% tint
okay, I got all tweeters and crossover brand new for 100 bucks. it's around 150 out there.
for diamond tweets, you need a 2 inch hole saw.
Tools you need:
Hole saw, electrical drill, screw drivers, wire stripper, wire, female prong (spell?), tape, and screws and washers to secure the crossover and about 3 hours of your time.
1)take off the panel, there are two screws, one you can see at the door handle which you pull to open the door and the other is the big one where you pull to close the door. remember to take off the black plastic triangle thing.
2)disconnect all the hardness, 5 on drivers side and 1 one passenger's side (there's one light bulb on both side which you turn to take out)
3)measure where you want the hole and drill a hole on the panel (better use a utility knife to cut out the leather first so it doesn't get twisted) where you want the tweeters, make sure they're at the same spot on both doors
4)glue the tweeters on the hole, let sit for around 45 minutes.
5)drill holes on the pocket if you wanna put the crossover there which I did. I drilled 6 holes total. 2 to secure the crossover and 4 for 4 wires.
6)connect wires on to the crossover (2 inputs and 2 tweeter outputs). put it in the pocket and screw in. pull the wires through the holes.
7)connect the wires with the female prong on to the tweeters and secure the wires on the panel
8)take out the 6.5 in mid-bass on the door (3 screws each) strip the two wires connected to it and connect the input wires on them.
9)connect all the hardness and the light bulb
10)put the panel back and enjoy!
Any Qs, ask Ron, Ed or me. Thanks!
Wood Trim Set
Gutter Guard Grill
Shock Sensor
Tools you need:
Wood Trim Set
Gutter Guard Grill
Shock Sensor
no problem.
Wood Trim Set
Gutter Guard Grill
Shock Sensor
Wood Trim Set
Gutter Guard Grill
Shock Sensor
DiamondJoeQuimby
09-10-2015 11:40 AM
alan_rich
09-09-2015 11:38 AM
