Internal transmission filter
Old Mar 5, 2016 | 03:16 PM
Mikehxbx's Avatar
Everything I've read indicates to the spin on filter when doing a change. I purchased an internal filter. How do I change it? Or will it be obvious when I open the drain pan?
Old Mar 5, 2016 | 06:18 PM
01acls's Avatar
It will be obvious when you remove the transmission and tear it down.
Old Mar 5, 2016 | 06:25 PM
musiclevelz5's Avatar
On Honda automatic transmissions, the internal filter is non serviceable.
You must take the transmission out of the vehicle and separate the case to get to the internal filter.
This involves a crazy amount of time and money buying new tools that you didnt know existed for transmission service.
Do a few drain and fills with DW1 and replace the spin on filter and call it a day. If your serious about the car, start saving money for an AV6 transmission to swap in after your transmission fails because its inevitable.
Old Mar 11, 2016 | 11:18 AM
Yikes's Avatar
Seconded.
As stated, you have to remove the entire transmission and then take off the outside casing.
At that point you might as well replace it with a better (AV6) transmission.
Don't waste your time.
Evilocity
Apr 22, 2016 09:33 AM
pnokio
Mar 22, 2016 06:10 AM
Hammer Time
Feb 27, 2016 05:12 PM
DJMikeT
Feb 21, 2016 01:22 PM
DJMikeT
Jan 27, 2016 12:03 AM
