Intermittent VSA, !, abs lights on
Old 03-08-2014 | 06:27 AM
James Thomas's Avatar
Like the title stated, it doesn't stay on all the time. I could start the car with it on and after a while driving they'll turn off. Then later they'll come back on. I haven't had time to go to a tire shop who could read abs codes so I just did the paper clip method (jumper pins 4 and 9 on obd2) and read the flashes. The results were codes 51 and 53 which are Motor stuck on and Motor lock. Hopefully I won't have to replace the VSA modulator cause that isn't cheap unless I can get one at the local scrap yard but all I've seen are the base TL I have the Type S which has a different unit. I would think if it's shot the codes would stay on. Well any help on this would be appreciated, I think I might have to get myself a multimeter and check some relays too. Thanks in advance!
Old 03-08-2014 | 08:38 AM
Nicks2001tl's Avatar
Have you done any recent work on your car?
James Thomas (03-08-2014)
Old 03-08-2014 | 01:05 PM
3.2TLc's Avatar
Check all of the associated wiring and connections. Could be something simple causing the intermittent fault. Maybe a short or bad ground ? Try a different relay.
Are you experiencing any actual problems while driving other than the warning lamps ?
Old 03-08-2014 | 04:24 PM
Only problems is lack of tcs and abs when the lights are on. Otherwise it runs like a champ. It started right before my tranny went, I had it rebuilt and up til about 2 weeks ago would stay on all the time. Now it comes and goes. I'll check the wiring and such and see what I can come up with. Thanks!
Old 03-08-2014 | 04:27 PM
Skirmich's Avatar
Need to check that ASAP cus all those lights on means = No Traction Control and ZERO ABS Breaking..
Old 03-08-2014 | 04:32 PM
Thanks!
Old 03-08-2014 | 04:35 PM
Skirmich's Avatar
Best possible scenario is that you have a loose ABS Sensor perhaps they unplugged it when they removed the axles to lower the trans.. Get the codes for the ABS if possible (Requires a special Honda tool).
Honda will try to rip you off to scan the codes but if your lucky get to a suspension shop and ask if they can read ABS Codes only (Different from OBDII Code reader but uses the same socket)..
With some luck they might have a generic reader and will charge cheap for it.
Old 03-08-2014 | 06:10 PM
I checked the relays and plugs and they all were good. However I decided to check the codes again and this time I got a third code 72 which is modulator unit failure. I did a search on here before but most also had wheel speed sensor codes as well so I guess i'll try my salvage yard and see if they can locate one for me. In the meantime I'll go to a shop down the street and have him pull the codes and see if his scanner matches the 51, 53, and 72 that I got from using the paperclip method. I also check the abs plugs as well. Thanks!
Old 03-09-2014 | 08:47 AM
3.2TLc's Avatar
Yeah, try to verify the codes. Sometimes stored codes need to be cleared and then rechecked afterwards for the current fault within the system.
Old 03-09-2014 | 05:50 PM
abnormalwrench's Avatar
9th Gear
I just went through this a couple weeks ago, 51 and 53 were because the pump motor was open circuit. Replaced the whole unit from the junk yard for $80. It is very easy to replace. When the light comes on, pull the relay and measure resistance from the output circuit to ground. Should be under 1 ohm. If it is above that, double check the ground at the motor, if that is good, you need the pump assembly.
The following 2 users liked this post by abnormalwrench:
3.2TLc (03-09-2014), James Thomas (03-12-2014)
Old 03-12-2014 | 04:54 PM
^^^^^Thanks will do.
Old 03-12-2014 | 11:11 PM
69tl's Avatar
mine does the same thing, which relay do i pull to check?
Old 03-14-2014 | 12:40 PM
9th Gear
ABS pump relay.
mada51589
05-03-2022 08:54 PM
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
Stu2414
08-30-2015 07:30 PM
Quick Reply: Intermittent VSA, !, abs lights on
