Intake question
Old Oct 29, 2002 | 09:13 PM
lhommec13's Avatar
Intake question
Do you guys consider removing the resonator and adding a K&N air filter as "adding an intake"?
Or would you define "adding an intake" as AEM, Icebox, etc. only?
Old Oct 30, 2002 | 07:56 AM
agean's Avatar
yeah i'm bored.
don't worry about what other people consider anything.
technically though, if you drop in a K&N, youre just changing the filter.
youre adding an "intake" if you change the whole piping, hence aem, injen, icebox...
Old Oct 30, 2002 | 08:44 AM
Well, technically, since you are removing the resonator, your not adding anything. I removed my resonator and put in a K&N, which I think works fine. I haven't done a dyno yet, but it's good enough for me. Whatever fits your budget, go with. Some will say that you get the same gains, other say you don't...
Old Oct 30, 2002 | 04:51 PM
lhommec13's Avatar
Yeah I already removed the resonator and dropped in a K&N filter, and I'm happy with the results.
Thanks for your replies.
Old Oct 30, 2002 | 10:05 PM
spyguy's Avatar
why remove resonator?
What does the resonator do? What does removing it do for you? I put a K&N filter in place of the stock filter, but I never messed with any resonator. What's the benefit, and how hard is it to do?
Old Oct 31, 2002 | 08:17 AM
Resonator is real easy to remove. It is in place to cut down on noise, and as such, causes some restriction in the airflow. Removing it allows more air to flow easier into your intake. It isn't that much louder with it removed either.
Old Oct 31, 2002 | 09:22 PM
Seotaji's Avatar
i would def. reccomend cutting away some of the tube that sticks into the fender, it flows easier.
Old Oct 31, 2002 | 09:32 PM
NSX4dr's Avatar
Original Member #81
With no resonator, K&N filter and Comptech mufflers I gained 12hp @ the wheels....
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
drone619
Jan 26, 2016 07:09 PM
IlliniAcura
Sep 19, 2015 09:31 PM
datadr
Sep 12, 2015 09:12 PM
