Intake install causing engine lights
Old Jan 8, 2004 | 07:27 PM
3rd Gear
Unhappy Intake install causing engine lights
Tonite my friends and I installed my new AEM v2 intake...we arnt mechanics but know what were doing for the most part...after we were all finished we started it up and got a check engine and tcs light...do you guys have any idea what could be wrong....
2000 TL
48800
Old Jan 8, 2004 | 07:33 PM
sc354's Avatar
Re: Intake install causing engine lights
2000 TL
48800
Well I personally would try disconnecting the battery and re-connecting it, this way the computer gets a fresh start, if not, then reset the ECU. I think I have heard ppl having to do this to their TL's after putting in a CAI.
good luck with that.
Old Jan 8, 2004 | 07:43 PM
3rd Gear
how do i reset the ecu?
Old Jan 8, 2004 | 09:06 PM
NYDesi80's Avatar
I thought disconnecting the battery from the car.. resets the ECU.. correct me if Im wrong people??
Old Jan 8, 2004 | 09:19 PM
goldendragon576's Avatar
TL-S driver
I just disconnected my battery for a bit. Have your radio code on hand, you'll need it. don't do what I did and freak out when my radio didn't work and I didn't have the card with me!!
Old Jan 8, 2004 | 09:47 PM
njtls's Avatar
you are correct...he is wrong
Old Jan 8, 2004 | 09:59 PM
rominl's Avatar
Re: Re: Intake install causing engine lights
so you mean..... reset the ecu again?! disconnect the battery already resets the ecu
Old Jan 8, 2004 | 10:08 PM
3rd Gear
I unhooked the battery...and waited a minute...it didnt work...should I wait longer....if this doesnt work....ill take out the 6 fuse...where is it located again??
Old Jan 8, 2004 | 10:09 PM
Mr Zipps's Avatar
Disconnect the battery for about 20 to 30 mins will reset the ECU and you should be set. Check that all the hoses are plugged in and everything is tight...
Old Jan 9, 2004 | 09:59 AM
car_lost's Avatar
updates?
Feb 25, 2020 09:57 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
