Installing OEM kit
Old Mar 28, 2002 | 03:28 PM
djkojione's Avatar
Installing OEM kit
Hey guys quick question,
Got my kit today and I was looking to install it. Read through the FAQ on the install but ran into a problem.
Is there anything i remove from the car before I install the kit, or does the kit go directly over the stock body parts?
I might be confused, but I need your help.
Thanks guys.
Oh...so how many people end up getting the cheap kits anyways?
Old Mar 28, 2002 | 03:34 PM
StanMan's Avatar
if it's like the 2002s, you need to remove the stock side skirts to install the new ones. the front and rear pieces are added on to the bumpers.
Old Mar 28, 2002 | 03:38 PM
djkojione's Avatar
hmmmm......thanks stan.
i knew the sides had to be removed, but to install the front and rear, you should be able to just put it on top of the bumber?
Old Mar 28, 2002 | 03:47 PM
djkojione's Avatar
Old Mar 28, 2002 | 03:56 PM
RAdams's Avatar
The front piece slides over the lower portion of the stock bumper.
The side pieces are replacements for the factory side sills.
The rear piece attaches to the bottom of the stock bumper.
Have fun!
Old Mar 28, 2002 | 04:04 PM
songoku's Avatar
BlingBling INSPIRE 32V
99-01 TL.
Front spoiler
you must remove the old spoiler front the bumper and put the kit. replacement part
-on.
Side skirts
remove 2 screws in the front and 4 clips on the bottom and remove the side sill panel by sliding the sede sill panel forward, and pulling it out toward you. replacement parts
Rear spoiler
rear spoiler should come with 4 spring nuts & 13 clips. Slide two spring nuts each side of bumper edge and slide the 13 clips bottom of the bumper cover. This is add-on.
Good luck!!
Old Mar 28, 2002 | 05:58 PM
jkc2121's Avatar
i got the cheap kit.
cycdaniel
Dec 17, 2019 10:58 AM
bailey24
Nov 21, 2015 08:43 PM
handsom-hustla
Nov 13, 2015 05:04 PM
nuldabz
Sep 3, 2015 05:49 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
