Installing AEM CAI today couple ???'s
Today i am installing my CAI with the bypass...I printed out the instructions from the faq, but i remember reading about having to cut some of the piping off for it to fit well, is this true, if so how much piping and from where? thank you
Loving my 08 TLS!
In the box that came with the AEM intake, it should come with a piece of paper that tells your the measurements in cutting the piping. You will NEED to cut the pipe if you want to install the bypass valve. Here is a pic of my intake, hope it helps:
![](http://www.geocities.com/typesdragon/pics/Aem.jpg)
hmm............i just cut mine straight through........i didnt cut off any parts...... i installed my bypass about 3 inches away from the intake manifold because i didnt wanna mess up the AEM sticker.......the only problem now is that my bypass valve touches my hood!!!!.....but not much damage =P
2002 Aegean Blue Pearl TL TYPE S
AEM Cold AIR INTAKE
Neuspeed FRONT STRUT BAR
EIBACH PRO-KIT (2.2/1.8)
AEM Cold AIR INTAKE
Originally posted by juniorbean
Yes, same thing, you need to cut the pipe to install the by-pass
Check out the link below, it's for the AEM, but installing the by-pass should be the same.....
http://wizardsworks.org/chod/acura/cai/
I looked at the link for the install, looks like that is the only instructions i have seen that doesnt require removing the front bumber...Is it possible without pulling the bumper? Thanks for all the help..
Loving my 08 TLS!
I didn't have to remove my bumper, wheel, or wheelwell lining. I just removed the plastic cover over the core support (radiator) and about 4 plastic clips on the bottom of the car to loosen the plastic trim under the stock airbox.
I also didn't have to cut my pipe, I just installed a shorter filter from Aerospeed and it fit fine. I didn't install the bypass valve either, maybe when I install my headers....
cycdaniel
12-17-2019 10:58 AM
InFaMouSLink
10-27-2015 06:51 PM
Abe_Froman
09-16-2015 01:27 PM
