Inaccurate temperature
Originally Posted by wmah523
my car does the same thing....it shows like 89 degrees when it's only like 55 outside. however, it slowly comes back down to 55, but for like 10 mins!
This reminds me of the problem with the climate control system. Occasionally it'll say "20" for the temp (I have a US model that doesn't use celcius) and none of the buttons work. Only way to unfreeze it is to move the temperature knob.
Originally Posted by fsttyms1
If it was a few deg off constantly we could tell you how to readjust. But for it to show that every once and awhile??
Originally Posted by Inaccurate
Did someone call me ? Did someone ask what my temp is ? Wait 20 seconds.... beep..beep..beep.... temp is 99.2 F. Sorry, I need to rest now. I am felling a little fever.
Originally Posted by Tanginaglaz
How do you readjust by the way? My temp is always 5 degrees higher than the actual temp.
Turn ignition on
Hold down both select and reset buttons
It will start a continuous "BEEP"
Then -3 -2 -1 0 1 2 3 will cycle through the outside temp section. Release the buttons on the amount you want to add or subtract to the current temp reading.
Originally Posted by 03CoupeV6
Turn ignition on
BTW Fishy, you're in Atlanta and you have a Canada-spec TL? Or is that one of those shockingly rare 240mph TLs that there was a thread about here awhile back?
Kris you're a douche
cycdaniel
12-17-2019 10:58 AM
CostcoFanAUS
09-18-2015 06:05 AM
09-17-2015 09:01 PM
