ignition switch
Old Oct 16, 2009 | 11:56 PM
taintedplay's Avatar
ignition switch
ok, i searched but didnt find anything. i have a lot of open room below my headunit. i was thinking of moving the ignition switch to there, and having a push button start. moving the ignition switch wont pose any problems will it?
Old Oct 17, 2009 | 10:24 AM
ok would i just buy this Part# 35130-S84-A01 (ignition switch part off the replacement diy)
and just extend the wires?
Old Oct 17, 2009 | 10:29 AM
fsttyms1's Avatar
Why would you have an ignition switch with key AND a push button? Why move it? why not put the push button by the radio?
Old Oct 17, 2009 | 10:32 AM
well you have to have the ignition switch even with a button if im correct. and just to be different. i have the radio taking up the top slot, (single din) and then just a blank spot below it. id have like the key hole right in the middle of that blank spot, with the button beside it. it would just be to be different. if i didnt like it i could always put it back too
Old Oct 17, 2009 | 10:48 AM
i drew this up real quick. the top part is the head unit, and from left to right on the bottom: push button start - igntion switch - footwell lighting switch - something else - battery voltage (for car audio)
opinions? or any tips on doing this
Old Oct 17, 2009 | 11:27 AM
hANDYcaptd's Avatar
It's the Halladay season!
Too much work for saving 2 seconds of turning the key and being different IMO.
But it's not my car. GL
Old Oct 17, 2009 | 11:34 AM
im going to have to redo the dash anyway so its not much work for me. but is all i do extend the wires on the igntion switch? and would it be a good idea to buy another one just incase?
Old Oct 17, 2009 | 09:12 PM
totaledTL's Avatar
What are you going to do with the hole left in the steering col. where the switch was?
How would it save any time? You would have to turn on the key first then move your hand to the push button-
Old Oct 17, 2009 | 09:40 PM
juanclopez2786's Avatar
youd still have to leave an ignition on the steering column or else you steering wheel wont lock. that would just make it easier to steal. leave the ignition where it is and add a push button start. or just get a double din and your problem is solved.....
Old Oct 17, 2009 | 09:47 PM
fsttyms1's Avatar
and you wont save any time. You will spend more time starting the car. The only good push buttons are the ones where you just need to carry the fob on you and push the button. Having to put the key in and just turn it to the run position then take your hand and push a button is lame. Why not just keep turning it to start the car
Old Oct 17, 2009 | 11:59 PM
i want to do it. i know its an extra step, but thats ok. and why coudlent i move the thing over? the steering wheel wont lock? im not sure what you mean by that
Old Oct 18, 2009 | 08:23 AM
on the ignition switch is built a lock for the steering wheel so when the keys not in it it wont move. once u turn the iginition it releases the lock. youll see when u take out the switch.
Old Oct 18, 2009 | 10:10 AM
is it ok if it wont lock?
Old Oct 18, 2009 | 01:16 PM
this shouldent be a hard mod at all, as long as the steering wheel locking thing isnt a problem. and yes i know its pointless lol
Old Oct 18, 2009 | 11:10 PM
ok so i was talking to one of my mechanic friends, and she wasent sure (she will ask tommorow in work) but she said it shouldent be hard, and she thinks you can bypass the wheel lock. ill keep you guys updated incase anyone wants to follow suit.
Old Dec 11, 2009 | 04:34 PM
anyone have any update on this? basically want to move the ignition to somewhere else on my dash.
Old Dec 11, 2009 | 08:14 PM
ChampionFiyah's Avatar
I agree with you dude, I think this whole idea it a total waist of time and money and if anyone here wants a car with push button start go out and buy a lexus or audi or something...
Old Dec 11, 2009 | 11:03 PM
ok guys its still something id like to do. waste of time or money, cool. still something id like. but, is moving the ignition goingto pose any problems? i heard about steering wheel lock but also heard maybe it could be bypassed?
Old Dec 12, 2009 | 09:19 PM
totaledTL's Avatar
Heard from whom? Ask whoever that is to explain. Still think the hole left in the column would look like sh*t.
MilanoRedDashR
Oct 8, 2015 10:30 AM
malvothegreat
Sep 29, 2015 12:38 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
h22lude
Sep 27, 2015 06:22 PM
eastcoastguy
Sep 23, 2015 06:29 AM
