Idling Problem
Old Sep 30, 2005 | 09:21 PM
2001andahalf's Avatar
Idling Problem
When idling, my car seems to surge...the rpms surge up and down up to about 1000rpm. While doing this, if the lights are on, the dashboard surges as well, dimming and then coming back to normal. To add to this, sometimes the car will jolt forward a second if my foot is off the break. When I had my '01 it had a problem similar to this and the "idle control modulator" or something like that was replaced. Could this be the same problem? Any ideas and prices to fix it guys? Thanks
Old Sep 30, 2005 | 09:28 PM
Bareback's Avatar
TL = Tranny Lubrication
maybe an issue with the plugs?
Old Sep 30, 2005 | 09:32 PM
plugs just changed...denso
Old Sep 30, 2005 | 09:33 PM
Bareback's Avatar
idle control valve? would about:
$87 part and $155 labor = $243
Old Sep 30, 2005 | 09:34 PM
1st timer's Avatar
UB6IB9
Check the idle air control valve,may need changing.
Old Sep 30, 2005 | 09:57 PM
thanks guys...appreciate it.
Old Oct 1, 2005 | 03:09 AM
fsttyms1's Avatar
IAC valve or egr related. (probably the first)
Old Oct 1, 2005 | 10:45 AM
2003TL-S's Avatar
Sounds similar to the problem I had recently and the dealer said the Idle Air Control valve was plugged up with carbon, fixed it, runs like new.
Old Oct 1, 2005 | 10:48 AM
PenancE's Avatar
where is it located? on the IM? if not easy to find/do?
Old Oct 1, 2005 | 12:07 PM
S power's Avatar
2010 TL SH-AWD
did you just reset the ecu? I notice when I resetted my ecu, my idle jumped up and down constantly for about 50 miles(ecu trying to adjust). then after my idle was smooth as a butterfly.
I dont know but i own a few honda before and everytime I spray cleaner in it, it gets messed up making the idle worst.
Old Oct 1, 2005 | 05:33 PM
MrAlex's Avatar
99 SSM Tl
At this labor price, better diy ..
my rpm was going from about 1000 to 2000rpm at idle .. i just changed my idle controle valve (on the bottom of the TB) and now its ok
Old Oct 1, 2005 | 09:02 PM
whatwasthat's Avatar
is there a pic showing the ICV? i wanna see if mine is getting clogged..
Old Oct 3, 2005 | 12:07 PM
Bareback's Avatar
Old Oct 3, 2005 | 12:23 PM
MrAlex's Avatar
99 SSM Tl
what is that !! this is not the idle controle valve at the bottom of the TB !
Old Oct 3, 2005 | 01:04 PM
Bareback's Avatar
According to this:
http://www2.acuautoparts.com/parts/p...+Valve&dp=true
It is.
Old Oct 3, 2005 | 03:50 PM
phipark's Avatar
Not Asian
It also says the "image is not application specific."
I would have to agree that looks nothing like the IACV.
Old Oct 3, 2005 | 05:38 PM
2003TL-S's Avatar
Yes it is on the bottom of the throttle body, but no it doesn't look like that. Ever since getting that fixed, my gas mileage has gotten better. How you may ask?
I do a lot of city driving and when I would come to a stop it would vary rpm's from stalling to 1000rpm's so I would have to keep my foot on the gas and break a little to keep her going. Seems to just run smoother in general now.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
TL14
Sep 24, 2015 04:37 PM
