Icebox?? Possible Problems with Install??
hello, I just got my icebox installed in my 03 tls and it sounds great, and everything was cool, but i have some questions...
1. We didn't replace the coolant line. is it really necessary to do so? We didn't wanna risk getting air into the engine.
2. When in park or neutral, i used to be able to step on the gas and floor it to redline. But now, while in park or neutral, it revs to 5000rpm and just stays there.... Is this a problem? What caused this?
3. We couldn't trim the battery cover so we just left it off for now... Will this become a problem to the battery or any other part of the car?
4. What do you clip the line towards the bumper to? It used to clip to the part above the bumper and a clip on the old stock box. But now it's just kinda laying around. it could still clip onto the front clip but we broke it so now there's really nothing clipping the line down. What should we do?
5. Aside from those four things, everything went well with the install! Will there be anything or should there be anything i need to worry about???
Thanks!
-Rob
Thanks!
-Rob
Liquid Ice
For #2, that should never have been the case. The car should *always* limit you to ~5000 rpms when in park or neutral. Redlines are not allowed ... I don't know how you were able to do it beforehand, but that isn't the norm.
Liqice is right on #2. ECU has a rev limiter at 5k for P and N. You'll never be able to red line when the car is at those gears
#3 if the battery cover is off it is no big deal. It just make it look prettier.
Tatewaki
Tatewaki
-Rob
Tatewaki
Tatewaki
Liquid Ice
Originally posted by ChillRobP
Okay, cool! That's reassuring. But i just remember reving my car higher than 5000rpm and stuff. I honestly remember doing it in the driveway making my mother mad and all that. But it's cool. As long as it's suppose to be like that, then that's all good to me! Just wanted to make sure before i started driving out there and stuff! My friend did a good job installing my intake for me! hey, by the way, sorry i couldn't come down a while back to do the Zaino thing. but anyway, how are things down there in va? weather wise... doesn't it suck??
-Rob
-Rob
Its cool about the zaino thing, I hope you were able to get your car looking good with the zaino! I love it, and just received my second batch of zaino products last week. Weather does suck, I hope it will be nice out by the 19th for the Import Xpression BBQ ... You should come out if you have the time. Free food!
Yea, how do you like the Icebox? I just ordered mine this week, hope to get it installed soon along with Comptech sways, springs, and Stone headers.
As for the zaino, i zaino'd it back in october, but since then i haven't been able to because with all the snow and rain the past few months, i just haven't had a way to. Plus, the temp. has been so low. But i don't think i did a very good job on it anyway, or maybe i needed more coats. Anyway, i need to take it to a detail shop! From winter though, from wiping down my car in the garage, i've got a lot of scratches, and swirls, and just at work the other day, someone dented my drivers side door! GRRRRR!!! i hate people that do that!!
CT provide a 19" and 12" hose to replace the metal tubbing attached to the stock box.
Compare the pics of the stock box to Icebox and you can see what I am talking about.
http://community.webshots.com/user/eleong123
On the way!
You won't get that much air into the cooling system by just replacing that line. It will purge itself out of the system, so go ahead and install the replacement line that came with the icebox.
I just got my kit and the instructions says the 19" line is the valve cover breather hose, and the 14" is the coolant hose. Does anyone have any closeup pics for me to see how these guys are attached?
Parting out 02 Type S :(
ok, i had the same problem. however, since my buddy did most of the install, i barely remember what to do.
on step 1 of comptech instructions, they refer to two sets of hoses. one of them is on top of intake, the other is on lower bottom side. the lower one STOCK should have a metal pipe attached to it, going into the engine. i removed the engine cover to see where it connects in and that really helped.
sorry i cant help more!
This is how I have connected the hoses, other member may have connected it differently.
Breather hose pic: (breather hose highlighted in red)
![](http://community.webshots.com/sym/image4/3/87/42/69838742ICpwnR_ph.jpg)
Coolant hose pic: (Coolant hose highlighted in red)
![](http://community.webshots.com/sym/image4/3/87/24/69838724hEQRrV_ph.jpg)
cycdaniel
12-17-2019 10:58 AM
Nitin
09-30-2015 08:22 PM
