how to tighten radiator to engine hose?
hose that goes from radiator to engine is loose and i can see coolent leaking a little near engine where it connects so i would really appreciate if someone can tell me how to tighten the clamps. thanks
Slide the calm off and try pushing the hose on tighter and slide the clamp back on.
it's the coolant hose, it doesn't have any hole but it leaks coolant where it connects to tb and i just send my dad to a local mechanic... i am gonna travel 200 miles so i can't take any chance...
Remove spring clamp and use screw style clamp. The spring clamps lose strength and don't clamp as well when you re-use them. Clean up the spout on the radiator as it will probably have some crud buildup that's causing the leak.
Like said above, go to a auto parts store and get a screw style hose clamp and replace the spring clamp thats on the car.
cycdaniel
12-17-2019 10:58 AM
09-17-2015 09:01 PM
