how to remove shift knob on a 1999 tl
hi i am just starting to mod my tl and i know some people with a 99 have have made their shift gate chrome by soaking it in paint remover. my question is how do i remove the shift knob in order to get the shift gate out. thanks for your help
a firm twist counter clockwise
Originally posted by s0ph3aktra
i wanna do what you're doing. how do you make the shift cover chrome? just soak it in paint remover?
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
This is from my '99 TL..
![](http://www.rsmooth.com/fileplace/users/illogic/DSCN0180.jpg)
-First gotta take off that plastic ring around your shiftplate..
-Then take off your shiftknob (Turn counter-clockwise)
-Then take off your shiftplate...you either gotta pull it to the left or right to unhook your shiftplate..don't quite remember.
-After that, use the "Graffiti Remover" to chrome it out.
@ slide or die @
Ok i finally removed the shift plate, no biggie. But are you sure that when i remove the paint, it will look shinny like Ill*TL? wich by the way looks sweet.
Boomer SOONER
Boomer SOONER
Originally posted by Seotaji
can you buy a 99 TL shift plate and install it in a 2000?
does anyone know how much that would be?
@ slide or die @
Yup no need to post, i did what ill*TL and OU SIG and it came out just like the pic posted above (exept i dont have that hole to the right side of the gate, i put piece back on) ...this is the cheapest/fastest mod so far...takes 5minutes to remove gate (if you dont know what your doing==>me),1 to remove paint and 1 to put it together.
total cost =$5.07 for spray can w/tax! and 7minutes.
