HOW to pull my own CEL code?
Old Feb 17, 2006 | 09:22 AM
payyourtoll's Avatar
Hey guys, I have a CEL on my car, and just bought a code reader to pull the code myself. Where is the plug for the code puller? I assume it is somewhere by the driver footwell but cannot find it, and search yielded nothing.
Also, I am assuming the correct procedure is to turn the car off, plug in the puller, start the car, and read the codes?
Someone who knows please advise
Old Feb 17, 2006 | 09:32 AM
whatwasthat's Avatar
the OBD or whatever its called is located unter the "not an ashtray" thing. you have to pull the small tab out. it's in the middle - between where the heat seat buttons are. you have to pull that tab out.
btw, you could of saved yourself some dough and just brought the car to an autozone where they pull the code for free. then come here and post the code, and we'll tell you the exact problem..
Old Feb 17, 2006 | 09:34 AM
NSXNEXT's Avatar
Hey payyourtoll, what year TL do you have? I believe they moved the ODBII connector on later model TLs. My 99 has it just where whatwasthat said but I believe it's under the steering column on later models.
Old Feb 17, 2006 | 09:36 AM
NSXNEXT's Avatar
I totally disagree. My ODBII scanner was the best investment I've made. Monday morning, 7am and my check engine light is on. Well I can either sit at home and wait till the local AutoZone opens and either drive my wounded car to the store, find a ride, or pull my ODBII scanner out of the glove box and test it right then and there.
Old Feb 17, 2006 | 09:41 AM
fsttyms1's Avatar
I agree. One of those may be my next purchase with a possible tranny swap looming around the corner
Old Feb 17, 2006 | 09:59 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
remove the tab underneath the ashtray.. then stick one end of a paperclip in one of the hole and the other end in another hole (im not at home right now.. when i get home i'll tell you which ones exactly). then, turn on the ignition, look at the CEL, it will blink. count the number of long blinks and the number of short blinks. let's say there are 4 long blinks and 2 short blinks (example), the code is 42. then look it up to know what it means (i'll post the list).
Old Feb 17, 2006 | 10:21 AM
I was under the impression that this only worked on OBD I, not II?
Anyways, like a few others feel, I think the code puller is a great investment for just $50. I also have a policy against Autozone doing ANYTHING to my car.
Thanks guys for the info on the location on the plug. Am I correct in plugging the reader in, THEN starting the car?
THANKS!
Old Feb 17, 2006 | 10:22 AM
NSX - my car is a 99, so I am ok with the location stated
Old Feb 17, 2006 | 12:08 PM
THANKS!
50$? i thought they go for $150+... my mistake. 50$ is a better buy i guess.. but meh, i''d rather buy some food for $50..
Old Feb 17, 2006 | 12:10 PM
here is the link to the $50 code puller for anyone interested
http://www.harborfreight.com/cpi/cta...emnumber=46030
Old Feb 17, 2006 | 01:06 PM
NSXNEXT's Avatar
THANKS!
Read the instructions but mine says to put the key in position II but do not start the car.
Old Feb 17, 2006 | 05:35 PM
trance957's Avatar
NSXNEXT
How much you paid for your ODBII scanner , at what kind is it.
08KBP_VA
Oct 22, 2019 01:55 PM
Skirmich
Oct 1, 2015 12:59 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
hrothgar02
Sep 28, 2015 11:08 AM
