How much is a timing belt?
Here is a list of parts that should be replaced when servicing the timing belt:
timing belt (14550-PGE-A01) $37.90
cam seals (91213-P8A-A01) $4.42 x 2
valve cover gaskets (12341-P8A-A00) $5.20 x 2
spark plug tube seals (12342-P8A-A01) $1.55 x 6
power steering belt (56922-P8A-A01) $9.72
a/c belt (38920-P8C-A02) $9.48
parts total = $85.64
The Acura flat rate time for replacing the timing belt and both cam seals is 3.7 hours. The average labor rate is $65/hour.
labor total = $240.50
total = $326.14
The price may be slightly higher/lower depending on the labor rate in your area, but this should give you an idea of the cost.
total = $326.14
What about water pump
Not familiar with the TL engine but is the water pump still behind the timing belt? If so, it's a good time to replace it too. Also, don't forget the timing belt tensioner/idler.
Home I'm not speaking out of turn, I'm speaking from experience on my old Legend. Is the TL timing belt setup much different?
Oracle Apps/Database Dude
Good idea to replace the water pump too. My mechanic in KC charges ~$480 for 4 belts (timing, alternator, balancer, something else) on my 92 accord. Her rates are the same for TL's
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
