how high do you REV when you accelorate?
Computer Techie
Hey guys I was wondering how high do you REV your engine when you accelorate? I normally go 2 or 2.5 some times 3 if I really need to (rarely), would it damage the car if I go higher? Would it cause more wear on the engine if I rev 3 or more all the time?
You're not going to damage the engine unless you exceed the redline on a missed shift. The rev limiter prevents you from overreving. 3000 isn't going to wear the engine...Honda engines are high revving motors...they like to be revved up once and a while. Take it near the redline and see how it sounds....it's sweet!
Are you saying you only rev to 2500 rpm normally?
The VTEC extra power mode doesnt even come on till 4700
So you can run it to 6000 all the time if you want- it wont care
Use good oil and filter and change regularly
If it was going to hurt the engine to go higher honda wouldnt have designed it to ref to refline in the first place. Floor it a few times and see how much fun it is. You wont hurt it
You'll Never Walk Alone
hey man how could you resist the temptation of flooring it and rev it to the redline? Anyways, you kept it under 2- 2.5k rpm...how did you do that? I find that I usually rev it to 3k a lot of the time, when there's not too much traffic around.
wow you guys dont mind eating so much gas? I already get shit mileage with a full tank. low 200s miles for full tank all city $45 to fill up and i dont fuck around all smooth driving.
AZ Community Team
Received 7,770 Likes
Rtfm
From this moment forward, you are offically banned from driving this automobile. Once you have read and understood the owners manual ( ), your driving priviledges will be restored.
:wink:
04 NBP 6MT
I try to hit VTEC at least once a day! Got to make sure the cams don't freeze up from lack of use. The only time I shift at 2,500 is when I'm stuck behind a minivan.
Check out http://www.pureenergysystems.com/new...00069_Acetone/
for more information
I was skeptical before but now with an engine that consumes less fuel, smoother acceleration and idle, i'm pretty much sold on it.
oh i should mention that i replaced the air filter with a k&n square filter in the box, been using Pennzoil full synthetic & k&n oil filter, took out the spare tire, maintain tire pressure at 30psi all around and running on sparkplugs with about 5000kms - i have 138000kms on the engine too
T-Swzy
i'm usually on 2000 rpm at the shift because my TL eats a ludicrous amount of gas.
i've never done acetone, but i've used the fuel injector cleaner stuff, and driving mostly below 2000 rpm i've managed 260 miles on 12.8 gallons of gas with 70% highway....wtf, is this normal?
Originally Posted by yukonam
hmm, might i suggest adding 3oz of acetone to your tank before filling up which is what i've been doing for the past 9 fill ups and on average with shifts at 5-6k mostly city driving I get 360miles or 580kms (i'm in canada) until the fuel light goes on.
I'd happy if I could get 580km before the light comes on for mixed driving.
Buddy are you serious? shift at 5-6k, city driving, and getting 580km?? I live in Canada too (Vancouver), where can I get acetone?? My car also has around 130000km on it, and k&n drop in filter. I also just used Quaker State fuel system cleaner a few weeks ago (since I can't find seafoam here).
i pick up a big can on acetone at the CDN Tire, it's ~ 946mls for $7+taxes - just don't get it on your paint, it will fade or strip it eventually if not washed off asap..
yea you might get lucky finding a source in bellingham or ask around the marine dealers about the Seafoam, if you're paying over $10/can you're getting burnt a bit
i tried using 92octane from Husky/Mohawk, but it dropped my mileage on the last tank to 520kms/tank.. It's mentioned in that website that lower octane gives better results.. So far, 91oct. @ Shell has given me 570kms and 8 fill ups at Mohawk/Husky at 90oct averages 560-580kms higher if i keep my tach under 3k especially on the hwy
let us know how you fare with your mileage if you try it out
thanks for the info. Before I put that stuff in my car, I just want to make sure that it will not destroy the plastic/rubber stuff in my car, as mentioned in that website. I think it says something like the acetone when mixed with even a little bit amount of water, can melt the rubber seal of something like that, and can really screw up the fuel system. Is that a problem associated with our car?
Anyways, 570km......thats still 170km more than what I'm getting now.
I'd defenetly be intertested in using acetone if it increased the gas milage that much. Why are you getting better results with a lower octane? I thought our car likes premium gas.
acetone supposedly has an octane rating of 140 or something like that, so I guess when it mixes with gasoline, it increases the octane somewhat. May be if you mix it with 94 octane premium gas with acetone, then the "actual" octane will be a bit too high and it might not combust as well? I don't know, just making a guess here.
how do you guys get up to 7200rpm and 4-5 normal driving??? do you guys floor it?? I do normal driving (1.5-2.5k) and even when im goin uphill on the freeway i only go up to 4k max. and im only 20
No He Can't
Originally Posted by KSuchdeve
And this thread is making me want to go out for a drive. A very spirited one.
I put in a de-Vtech controller to only allow me to rev to 1000rpm. I get about 600 miles on a tank. Vtec kicks in @ 469rpm. It's orgasmic.
You've got that right. Today was a beautiful day for a wash/wax/country drive...
Haha, true that. If only they made upgraded cams for the TL... that'd be hot. I hate Civic/RSX owners. It's not fair that they get all the good parts.
Originally Posted by ChrisQ1980
Seriously. It's nice and cool here now as well. CAI gulping that cold air up.
T-Swzy
I'll take it to 6000+ every single time I drive it. Nice to gate shift and bounce it off at 7200, but I can't look for cops at the same time.
It would be sweet if there was a new DOHC V6.... SOHC ftl
it would be nice if they introduce J32B or J35B.
Originally Posted by Razzi
my car idles at 800, how the hell does that work?
Originally Posted by fsttyms1
Rumor has it its coming, and chain driven instead of belts
Has their been a modern Honda automobile with a timing chain as opposed to timing belt in recent years? I'm assuming you meant chain driven as in timing chain
May still have hope for Honda yet to come out with some major changes for the TL. Of all things though I doubt it will be chain driven instead of using a timing belt, Honda even put a timing belt in their most expensive automobile, the NSX.
why are they dogging on honda for making reliable cars >.>
oh and woot woot for DOHC V6
