how hard is it to change the oil?
Ex-Acura Die Hard Veteran
Can someone explain it to me real quick, Im too busy to go somewhere. I wanted to knock out my TL and sister's Teg. Im over by like 2500 i noticed yesterday.
Dave
Dave
the bolt is on the right side on the tire, you open that and the oil falls out, and since the oil filter is also near by that that out then after all the oil is gone replace the filter and screw the bolt on and fill the car with new and clean oil. done its about 15 min job, but if you warm the car up before draining the oil flow will be faster.
How many bottles will each car take?
there is a TL and Integra.
What is a good brand/weight?
Also, is the bolt and filter on the integra in same place? Do I have to raise the cars?
Dave
Dave
its about 3 and a 1/2, you can go 4 you want 5w-20 but you can got with 5e-30. i',m not sure about the integra but you might have to raise the front if your oil pan is big.
I use to use whatever oil is on sale. But now, I use RedLine Synthetic Oil. I used about 4 quarts, maybe 4.5. An integra would probably use 4 or 4.5 quarts as well.
It's better to over buy and keep a few quarts on hand in your garage.
Don't buy FRAM filters. They are pretty much garbage. I bought the top of the line filter at Pep Boys. I forgot what it's called, but it was like $8 bucks or something. Purolator Premium or something like that.
How hard is it? Well, I just changed the oil the other day and boy, I wasn't prepared for the tremendous spurt/gush of oil that poured out of the oil drain plug opening! Even after positioning the oil drain bucket to account for this and putting cardboard right underneath the pan and nearby, the oil still shot out like Peter North! Got all over my arm and spurted a foot or two past the opening all over my garage floor.![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
Perhaps next time I'll keep the oil filler cap on until after I remove the drain plug...
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Censored User
Location: Miami - just one day, I would like to drive without getting cut off!
how to contain the mess....
My dad use to use an old baby tub to collect the waste oil. Might work if you can fit it underneath. You Eibach/H&R investors might trouble with that though.
Purolator, is pretty good but i recently saw that k&n now make oil filters. i know the frist time to get the stock oil filter out is tough i even bought a oil filter wrench at pep boys and it really helped but after that its really easy to get it off.
Retired MOD
1 Post
bwahahahahah peter north.... oh man that just made my day.... hahahah
Lucky for me the grease monkeys at the dealership didn't super-torque the oil filter on, as I was able to remove mine without the need of an oil filter wrench or even worse, the "punch a screwdriver through the filter" method...
Tony
Originally posted by TLover8888
and you think Purolator is better?
Sooo....if you have data or research or know more information, please enlighten me as I am always looking for better products.
If you know that both filters are terrible, what are your recommendations?
Thanks!
Stealthy A-CL Member
Dave
Dave
I also replace the aluminum washer with a new one; they're like $0.25/each at the dealer.
Originally posted by IntegraVT
Oil changes on the 'Teg are ridiculously easy. The drain plug and filter are easily accessible...
I especially like the fact that the oil filter is mounted upside down instead of sideways...
There are 2 types of Purolator oil filters. One is the crappy one and the other one is decent....well that's what I've been reading on people doing their own independent research.
Thanks!
Thanks!
http://ntpog.server101.com/reviews/f.../filters.shtml
http://www.minimopar.net/oilfilterstudy.html
Retired MOD
1 Post
hmm so k&n are good huh, i should try them and does anyone know what is the best oil filter out there????
Dave
Dave
Originally posted by Bitium
So far the K&N so good. Is hard to determine which one is the best, but I heard that mobil1 filters are also good. I'm sticking with K&N for now.
Hmm so has anyone tired Mobil 1 and what do you think about there filters???
mada51589
05-03-2022 08:54 PM
