how to check for bent rims
how do i check for bent rims? can u spot them by eyeing the rims?
today i ran over a big pothole, but only doing about 26mph. just by looking at the rim face, they look ok. i also poked my head out and checked the rim while it is rotating, and they dun looked to be warped. but the question is do i need to dismount them to see if they are dented or not. and does anyone have pics of dented rims??
I would take if off with a tire machine, and just check to see if it has any visible signs and stuff. then just reseal it with beadsealer and put it back onto the rim and balance it, as long as there is no huge differences it should be fine.
Blown is Best
Find a shop that has a Hunter GSP9700. The machine applies a load to the tire, checks wheel runout and then checks tire runout separately. It can tell you if your within tollerance. It will also optimize the placement of the tire on the rim. Both tire and rim have some runout so it determines how much to rotate the tire on the rim for the optimal assembly. Go to Hunter.com and look at their products under wheel balancing machines. It can help you locate a shop with one of the machines in your area.
I had mine done and the ride improved drastically. They also identified one of my rims as being marginally within tollerance.
I would just bend down and look at the lip of the rim, inside and out. If you are still not sure, ask someone else to drive the car and look at the rim and see if you see anything. Even a small bend will make the wheel look its out of round.
If you dont see anything, and the car runs right without any vibration, or wobble, why go through the hastle of dismounting the tire and possibley having the shop scratch your rim to see if its bent?
Livin in NYC, Id never be able to drive my car anywhere other than the tire shop if I took it into the shop everytime I hit a pothole.
the car runs fine, no wobbles during high speed (110km/h), and right after i hit that pothole, i stuck my head out, they seem not bent, still makes a nice round circle when rotating. thanks for all the replies though. yeah, i dun think i have a problem (hopefully). now i highly recommend these motegi rims, not bad considering they're ok "cheap", good stuff
When there is a problem with a rim or a tire, the easiest way to check is to see if there is a vibration at any speed, which seems like you already done. If car runs fine, there is only like 0.1% chance something is wrong. If you do feel paranoid, get wheels checked on a tire balance machine. Tires do not have to be dismounted. Or just try to go 200 km/h, see if you get any vibration then.
no, that's not me, i have a heather mist, not lowered, and just got my rims 3 weeks ago!! and also I usually just hang around richmond on the weekends and ubc during the weekdays.
Go on the freeway and go from 50 mph - 70 mph, you will feel a vibration or your steering wheel shakes a little bit. Don't matter if it's rear or front, it will have the same effect. If you get it balance, it might not solve the problem because those machines only spins up to certain speeds.
I bent my rims one time and you can tell when your driving if your steering wheels shakes alot at high speeds...or you can take to discount tire and they can but it on some balance thing and let you know
