Hight Temperture
Hight Temperture
So i seafoamed my car(thank you for diy) and my car is hella faster now. But now for some odd reason when idleing the car temperature gauge goes up but when i shift into gear and step on it tempeture cools down?????
so does anyone know what can be the problem, the car is a 2000 acura tl-p
well it was low today (the coolant so i added some than it started acting wierd) but i have 92 k miles
it cools down when you drive cause the belts make the water pump move faster thus moving more fluid through the motor. If you car ever heats just put it in the lower gear you can to keep the water pump moving the fluid as fast as possible through the system.
does the radiator fan turn on. try sitting still wait till it gets hot then turn on the a/c. it has a seperate fan.. if the temp goes down then your primairy fan isnt turning on.
if it gets cooler while your driving its cause air is cooling the radiator. and sitting still your fan is supposed to do that.
seafoam had nothing to do with your problem
3-4 lines of temp means a major issue and should NOT be driven until fixed
First most likely is thermostat- movement causing airflow lowers temp
BUT thats a lot of needle movement!!
Or water pump is failing- with low colant level thats my first thing to check- where is it losing coolant from? nothing matters until thats resolved
Check under the wp for coolant leak from a small weep hole cast into pump body
Ck rad cap seal for leakage
pressure test cooling system
The seafoaming had nothing to do with it.
Here is a question, What vac lines did you use. Did you take any thing off of the TB and possibly get them mixed up because there are coolant lines on the TB.
well now the car is doing just fine i did some driving around on it. so now it doesnt go above half way mark. I dont know what could have caused the problem
