High revs caused by map sensor?
UB6IB9
Today my car was reving at around 2k rpms,i unplugged the map sensor and the revs went just below 1k rpms. What does this mean?
does this mean you fixed the water pump and this is an unrelated issue?
or have you overheated the engine enough times that its starting to sieze??
there have been some recent failures of TPS throttle position sensor and required TB replacement
UB6IB9
It overheated once 3-4 notches before red,the other 2 times just 2-3 notches above normal. Yeah this a separate issue. I replaced the Map sensor and the idle is back to normal. The only things left to do are,timing belt water pump,rear main seal,ball joint,valve adjustment and clean the iacv.
UB6IB9
I dont recall if it was entire tb or sensor was able to be replaced in other cases,
Im getting old- memory full
How much was your part and where does it go?- for the next person trying to figure it out
UB6IB9
So it's your coolant temp. sensor that cause the erratic RPM in your 99TL ? My cousin 99 Tl got the same problem with Rpm going at 3500rpm at stop when engine and outside temp is hot .
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
09-17-2015 09:01 PM
