HID Problem
Old Feb 1, 2013 | 05:31 PM
DannyDee's Avatar
HID Problem
I purchased some D2R 4300 bulbs and they finally came in.
I took off the old ones and put in the new, but only 1 side works. Passenger works, driver side does not.
I plugged both bulbs into the passenger side and they both DO work. So I know it is not the bulb.
On the left side, the connector (pictured) might be my problem?
At first, it did illuminate the bulb but just for a quick second. Now 5 minutes later, it does not even do that.
At one point I did not have a bulb connected to it and when I turned on the lights it made a buzzing sound.
Now it just does not buzz at all.
Old Feb 1, 2013 | 05:44 PM
DannyDee's Avatar
Also, I highly doubt it is my ballast due to my lights NEVER giving me a problem until now.
Old Feb 1, 2013 | 05:47 PM
3.2TLc's Avatar
Maybe a bad ignitor unit or ground problem. Perhaps you could check for power @ the connector ?
Old Feb 1, 2013 | 05:51 PM
DannyDee's Avatar
How do I do that?
Old Feb 1, 2013 | 06:00 PM
3.2TLc's Avatar
You could check the fuses, #43 & #45 both 20a. If they're ok, try swapping the L & R relays for the headlamps.
Make sure that the connectors are not corroded or loose. If you were not having any previous problems, it may be something simple. Did the affected side's headlamp burn out or was it just turning yellowish pink ?
Old Feb 1, 2013 | 06:06 PM
DannyDee's Avatar
Fuses are okay. Nothing was wrong with the affected side. I only swapped them out because I got the bulbs for cheap and just wanted a brighter/newer look.
Old Feb 1, 2013 | 06:09 PM
DannyDee's Avatar
I was thinking it was something simple since I was having no problems until then. Tmrw I'm gonna take the bumper off to see more. Hopefulyl its just the connectors
Old Feb 1, 2013 | 06:19 PM
3.2TLc's Avatar
Did you encounter any difficulty when removing the original bulbs ?
So, both of these "new" bulbs will work on the one side. Maybe try the old ones again ?
Old Feb 1, 2013 | 08:47 PM
duran492's Avatar
bro .. i have the same problem with my lights .. if you flicker them long enough it'll turn on eventually .. i have no clue how and where to ground it from the ballast to the frame.
Old Feb 1, 2013 | 09:47 PM
DannyDee's Avatar
it's annoying man
I gotta try that tmrw too
Old Feb 2, 2013 | 06:34 PM
DannyDee's Avatar
Update:
Took bumper off and took off the ballast on the side that is not working.
I got the working ballast and swapped it to the other side and I am only getting a constant buzz. There is power getting to it though.
I checked the relays aswell. Could there be a problem with my grounds connecting to the harness?
Old Feb 2, 2013 | 07:43 PM
3.2TLc's Avatar
While ya have it apart, it would've been a good time to update the original HID unit with the smaller waterproof kits available for less than $100. It may be something with the inverter/ignitor ???? Doublecheck the wiring and connection.
Old Feb 3, 2013 | 11:06 AM
fsttyms1's Avatar
Sounds like your ballast may be shot.
Old Feb 7, 2013 | 10:08 AM
DanTL-S's Avatar
I'm also having a problem with mine, so one day they just suddenly stopped working, i checked my fuse and it was burnt out! I changed it the next time and BAM it was back, I turned on the fog lights for a second check them out and it was suddenly
Old Feb 7, 2013 | 10:11 AM
DanTL-S's Avatar
not working anymore, so i changed ballasts/igniters for new ones and the light works again but it is NOWHERE near as bright compared to my other one. The light comes on but honestly it looks really dull and personally a little "purple", my father says otherwise,but it's still no where as bright as my other headlight. Anyone know what's wrong?
Sorry for my UN-continued post above.
Old Feb 7, 2013 | 10:38 AM
MilwaukeeDave's Avatar
They have a burn in time I believe. They will get brighter after so many hours of use.
Old Feb 7, 2013 | 11:13 AM
DanTL-S's Avatar
Well I've had them on basically anytime I drive and it's been about two weeks with no sign of getting brighter, do I just need to give them more time?
Old Feb 7, 2013 | 11:15 AM
I think it's about 50 hours of on time if I'm not mistaken. That's a while really when you think about it.
Old Feb 7, 2013 | 11:29 AM
DanTL-S's Avatar
Oh wow 50hours? Oh, looking at my other post, the new ballast/igniter isn't "new", but it is new to me. So yeah...they're used... I was thinking maybe those are dying out too. What's your opinion?
Old Feb 7, 2013 | 05:11 PM
3.2TLc's Avatar
Hey DanTL-S, I'm unsure if you replaced the bulbs on both sides.......but if not, it's recommended to do both at the
same time for a uniform appearance ! Makes sense, don't worry about the ballast/ignitor as long as it's doing it's job.
Did ya get 5k replacement bulbs ?
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
