HID Lights
HID Lights
About a month ago someone stole headlights from my 1999 TL (!). I took it to the body shop and got it fixed (got new headlights, bulbs, etc) but now the lights are not as bright as they used to be and the beam does not shine as far as it used to. Plus the light has a yellowish color to it that it did not have before. Can anyone suggest any explanation? As far as I know there is only one type of light bult that goes into that headlight. Also does anyone know where I can get more information/drawing/schematics that would explain all the details around the HID lights?
As for the beam not being high enough, that is a matter of adjustment. But i have heard that Xenon bulbs have a break in or burn in period. When my cousin first purchased his BMW his Xenons were a bit on the yellow side, then they became very deep blue after a little break in. Complain to them and tell them you will give it a month. If it doesnt work, have them order you a different brand of xenons.
Re: HID Lights
What is the 6000k bulb? I though there is only one type of bulb hat goes in 99 TL headligths..
You can get the 6000k in either D2R or D2S. But only the D2R will fit perfectly with the oem light housing. If you want the D2S, you will need to make a little modification to the base to make it fit. IMO, the D2S is a little brighter than the D2R.
Here is a stock TL D2R 4200k HID:
And here is D2S 6000k on a TL:
question... im not to informed on lights but arent 6000k bulbs going to be illegal? cuz im not sure what the new law or whatever is on HIDs now ... i know a friend of mine had some bright ass lights, i forget what kinda bulbs , but he kept gettin pulled over for being too bright... wud puttin those bulbs make u more likely to be pulled over?
Now the problem is that these damn ricers put in those fake a$$ bright lights and have them pointing up to the sky and blinding people.
I had my 6000k since the end of June and have no problem so far. I even stayed behind a cop a few times and nothing.
Why'd they steal 99 HIDs
They are D2R and it won't fit anything else. The ballast and ignitor are probably worth something, but they'll only fit D2S or D2R bulbs. But if they pick on them, they must have a way to turn them into cash. Damn jackers :flamer:
Tatewaki
They are D2R and it won't fit anything else. The ballast and ignitor are probably worth something, but they'll only fit D2S or D2R bulbs. But if they pick on them, they must have a way to turn them into cash. Damn jackers :flamer:Tatewaki
Tatewaki
Apprently the '99-'01 entire headlight assembly will fit on '98-'02 Honda Accords with slight modification.
Needs to modify front bumper with grille, both fenders, hood, and have to make some space for the ignitors under the headlights.
This requires re-painting whole front end. :o
hm.....my bro just put some 6000k hids on his civic, bright and pretty...
from a far distance, i can mistaken it for a lexus or an acura or some other high end car
but too bad it's just a civic
Does anyone on here who has the 1999 TL with original factory lights live in Northen NJ or NYC? I am getting very frustrated bealing with the bodyshop and Acura dealers and wanted to compare the light I have know with another Acura TL with original lights.. I appreciate any help..
Originally posted by kwieching
Blackshadow....
What is the difference betwwen D2R and D2S look wise? Is one brighter or bluer than the other?
Blackshadow....
You can meet up with Joey (bdimc2001 on this board) in west orange to compare lights. He has a 2001 TL with stock HIDs and it is the same as the 99. You can pm/im/e-mail him.
Thanks BlackShadow.. For some reason I can't look at any of the member profiles (!) so I don't know Joey's email (or anyone else'). Can you give me Joey's email address? I hope Joey doesn't mind..
Thanks again..
Thanks again..
Originally posted by brado
is there a website where i can purchase these D2R headlights?
thanks a lot for the help.
Originally posted by peiqinglong
PM Songoku...he has a guy that has a shop in Taiwan that sells HID bulbs for cheap. They're Phillips and Osram, not cheap brands either. THe guy ships overnight too I believe. I bought my lights from him.
Autolamp-online
BoricuaTL
Apr 8, 2016 01:08 PM
