HID Kit, Advice Needed, D2S vs HIDextra
Old Jun 9, 2011 | 01:21 PM
derning's Avatar
4th Gear
Hey dudes and dudettes.
On my 2nd gen TL-S, my HID ballast/igniter just got fried ... AGAIN. This time I think it was from the pressure car wash, water getting into the ballast or something like that. The bulbs are probably fine. So I went ahead and ordered a fresh set of gaskets from AcuraPartsWarehouse.com, based on ClubRacerX's recommendation in this thread:
https://acurazine.com/forums/showthr...highlight=part
Instead of spending all my precious cash on dealer parts again, I'm considering an aftermarket HID conversion kit. What do you guys think about the D2S kit vs. the HIDextra kit?
Ease of installation? Reliability? Appearance and color? Customer service? Any other options I should consider?
Any advice would be very helpful. Thanks in advance.
~Derning
Old Jun 9, 2011 | 01:24 PM
pickler's Avatar
neither get D2R kit, D2S kit will have too much glare without porjectors. i had people high beaming me with D2S 6000k, i switched back to oem osram D2R 4150k and im very happy. its much brighter than the 6000k and there is no glare.
Old Jun 9, 2011 | 05:30 PM
01tl4tl's Avatar
I have the d2r kit from hidextra.com with 5000k bulbs
takes a minute to figure out you have to do slight mod to the housing for the ignitor cable connectors to fit thru the wire hole- (I used a flat file on its edge to make an access path-doesnt take much extra room)
and where to mount the ballast, but the rest is easy
tip: run an external ground wire off the ballast to a cleaned spot on the frame
I was able to hide all the parts under the bottem of the housing- as its slid into place
Old Jun 16, 2011 | 05:09 AM
derning's Avatar
4th Gear
Good stuff, fellas. Thanks for the tips.
I just ordered up a D2R kit from hidextra with 5000K bulbs and the slim ballast upgrade. Will report back once I get it installed.
Old Jun 16, 2011 | 10:02 AM
01tl4tl's Avatar
for others:
no need for the slim ballast- mine mounted to the frame rail under the housing just fine
Old Jun 16, 2011 | 10:03 AM
01tl4tl's Avatar
call them back and order the `relay kit` too--15 bucks
the TL seems picky about voltages and resistance thru the stock system,,
Old Jun 16, 2011 | 09:22 PM
derning's Avatar
4th Gear
Do you mean that I should get this "Universal Relay Harness?"
http://www.hidextra.com/universal-hid-relay-harness-343
Old Jun 16, 2011 | 09:46 PM
01tl4tl's Avatar
yes thats the one
Will bypass the stock wires and relay system with its own, one that will handle the changes made to current draw with different ballast and bulbs
Soul_Deamon
Nov 13, 2018 04:44 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
pozebly
Sep 23, 2015 07:30 AM
nuldabz
Sep 3, 2015 05:49 PM
voigt
Sep 2, 2015 10:44 PM
