Hid Diy
Old Aug 5, 2004 | 01:14 AM
Hid Diy
Does any know where I can get a DIY for replacing the HID bulbs? And what tools you need and if there is anything I need to look out for when swapping them out.
THX
Old Aug 5, 2004 | 01:21 AM
edgalang's Avatar
Purchased: April 28, 2001
THX
You'll need a special allen key to take screw #3 out. Personally, I was able to get by it with a set of heavy-duty needle nose pliers (pain in the ass...but dooable).
Once you take that out and unscrew the cover off (#10)...you'll be able to see the igniter (#2)
Twist the igniter a quarter-turn and it'll expose the bulb held on by a metal clip that the picture doesn't show. Unclip, replace and rewind and you'll be set.
Old Aug 5, 2004 | 02:07 AM
Thx, is the clip hard to take off and put back on? And before I put in the new bulb, should I wipe it with some rubbing alcohol or something to get off any prints or etc..?
Old Aug 5, 2004 | 02:08 AM
Also, does anyone know what the special allen key is, and where i can get one?
Old Aug 5, 2004 | 04:33 AM
edgalang's Avatar
Sounds like you've exchanged bulbs before. If you want to clean the bulbs go ahead. As far as the allen wrench is concerned...I suggest taking a look at it first before you go buying anything. With a small enough flathead screw driver, I'm pretty sure you can twist it off.
Old Aug 5, 2004 | 10:56 PM
Yah, but I don't wanna screw up these bulbs, they cost too much, lol
Alrights, thx
Old Aug 6, 2004 | 12:30 AM
NYZGREATST's Avatar
Sig Rho's Finest
u need a special torx head screwdriver with a hole in the middle. i got mine at a local hardware shop for 2 bucks. i just took the whole headlight to him and he found a match. the clip is easy to take out and a semi bitch to put bak in BUT its doable
Old Aug 6, 2004 | 03:20 AM
you can change the bulbs without taking out the whole headlight unit though right?
Old Aug 6, 2004 | 03:55 AM
edgalang's Avatar
Yup...but like I said....go outside and take a look first. It'll make sense to you if you just saw it in person.
Old Aug 6, 2004 | 04:14 AM
hzm82's Avatar
I believe you need a secure torx 20 (or was it 12?) screw driver. Make sure you get secure torx, because the regular torx won't work. When I changed mine, I just used a small flat headscrew driver. It worked out just fine.
I also disconnected the ballast also since it run such high voltage.......atleast disconnect your battery. Better safe then dead.
Old Aug 6, 2004 | 04:16 AM
HAHA, alrights thx guys
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
