hesitates from a dead stop
Our 99 is just over 100k, and we noticed as of recently that the "getup and go" from a dead stop is non-existent for the first second or so. The motor does not rev, it just does not respond quickly. I am thinking fuel filter, plugs, wires, pcv, injectors, timing, what????
any ideas please post
when moving is there hesitation in how quickly it responds also?
check for play in the throttle cable
hows teh idle? is it rough? if it is id say plugs are in order and if they havent been changed yet they are in order any way
the reason I assume this is that should the plugs really be at fault, gas would flood a bit with no fire. Once the plugs fired enough to burn off the gas, it would either produce smoke, or at least a collective soot; but neither is visible
with cloged injectors they would all need to be clogged teh same or they would have a rough idle due to 1 cyl not being as efficant as teh rest. if it were plugs you would have a rougher idle or worse mileage and performance.
thats why i first said to check the throtle cable for slack?
even with something clogged or plugs bad the engine wouldnt have any lag time from original throttle tip in unless its not actually opening the tb
Mine does the same thing, its gotta be something like the air control valve, egr, just seems like the air mixture is screwed up somehow. This hesitation only happens after a cold start
I need 2 more gears
gumout fuel system cleaner, new plugs and clean your TB and check your air filter too. do all those things and i guarantee your car will be running better! if still not where you want it, tranny flush, new coil packs or new battery would help.
dont forget the pcv valve. makes a diff. u might want to have your o2 sensor checked. if your running rich for a long long period of time it accelerates the deterioration of this sensor............... then the catalytic converter starts to wear..........blah blah blah
hope u get it fixed
hope u get it fixed
Originally Posted by 03CoupeV6
Wouldn't EGR, O2 sensor, PCV valve problems cause the CEL to illuminate. Obviously, that isn't the case for him.
MrHeeltoe
20
02-23-2023 01:54 PM
SidhuSaaB
05-30-2020 12:40 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
