HELP.. rounded off bolt
13.2@106mph G37 RWD Sedan
i was trying to change my oil for the first time on my tl today after 10k.. i used to get the little oil shops to change it quickly but today i decided to do it myself after putting some seafoam in it..
i didnt have a proper jack the one i had was messed up and wouldnt lift the car high enough thats why i couldnt fully get under the car so i had to really reach my arm under in there
so everytime i would try to get that bolt off.. the wrench would slowly slide off.. that bolt was pretty much stuck in there...i think that must have made the edges of the bolt round off.. i used a 17 mm socket by the way..
i know its a pretty dumbass mistake i made but i need some help now in how i might be able to get this rounded bolt off
without taking it to a repairman i also tried using vicegrips after it got rounded but that made it worse
I was going to say visegrips but looks like you already tried. I would try again with the biggest ones you can find. Tighten it up as much as humanly possible onto the drain bolt and pull! If that doesn't work you may have to get it on a lift or really high on some jack stands and drill a hole in the middle of it and use an easy-out to get it off.
17mm 12point socket and some epoxy to glue it on let it cure over night and give it a shot, you can also cut lines into the rounded hex head in order to give the epoxy more surface area to grip on.
Make sure you have a crush gasket waiting to put on when you put the new drain bolt in too
If a good set of visegrips wont get it- go to a shop
needs more leverage!
This is a common prob with speedieshops- drain plug way past 29 foot pounds torque
Hope the threads in the pan are not damaged- they can get pulled right out!!
Not sure what socket you used but if its a 12 point get rid of it. Find a 6 point for future uses. Get a set of ramps or a better jack to lift the car properly, and a set of jack stands for safety.
Go to your local home improvement store and buy a set of these.
Irwin Industrial Tools 394001 Bolt-Grip Bolt Extractor Base Set, 5-Piece
I believe they make a metric and standard set.
I've used Sears version of those (although not on a drain bolt) & they worked well. Use the one that fits the tightest. It's worth a try.
thanks for the help guys imma try the vice grips again but at my buddys house hes got a 5 foot landing in his back yard ima drive my car tires right to the edge of it then i can stand under the car and work on that bolt way easier
and ill check out those sockets for the rounded bolts at home depot if they have any
This is what I've done,even tho this is on a drain plug,it shouldn't mess up anything.
Use a flat head screwdriver towards the side of the bolt and give it a few good hits (just make sure you're going in the correct direction).
This should break the bolt lose enough where you'll then be able to use vise grips to get it off. I've done this before and worked every time, hope it helps.
hey thanks for your help guys but none of that stuff worked so i took it to my mechanic and he even had a tough time getting it off but he managed to get it off with a impact gun and changed my oil all for 20 bux
i had to buy the new bolt from acura for 8 bux though
he said it was the damn speedy oil change people that mustve used a impact gun to tighten the bolt right on
i had to buy the new bolt from acura for 8 bux thoughhe said it was the damn speedy oil change people that mustve used a impact gun to tighten the bolt right on
Bonki' Ehrite!
did you learn a lesson from this
