HELP PLZ! Urgent NO brake lights!!
Hey was trying to install my LED plate bulb I had the car on ACC with the accessory light on, ex: tail light front yellow. The plate light accidentally came into contact with a screw driver tip. I now have no brake lights, rear tail lights or interior dash lights at all!! HELP what did I do. Only my front headlights HID and fogs work along with reverse and turn signal in rear what do I do????
I think I blew a fuse, i checked the obvious but they all look fine HELP have to get home after work in dark!
Threads dont get closed. We keep them open to at you
j/K but we do keep thing open.
fuses can never be visually confirmed- they will fool you
When touching a Hot wire to ground = blow a fuse to protect the system
surprised it started without using nuetral switch override
I'm in idiot I know, the 194 LED didn't fit in the socket so I took a screwdriver to pry the tabs to make them a little bigger. Thats when it all started. LOL! I feel like a NEEEEWWBBB!!
oh, well as long as your were modifiying a bulb socket to jam the wrong part in---
we wont hassle you about shorting out the system when we all know to remove batt neg when doing electrical work~
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
